LazyMasterGamer
so I've been trying to install Sinusbot on my VPS and when I try to run it with the command ./sinusbot it's not starting, nothing is printed in the console and it goes directly back to the normal prompt line. I've tried to run it ad root and as sinusbot and I used LogLevel = 10 (still no output).
I ran the diagnostic script, here is the output:
Thank you for your help, have a great day
- Operating System: Ubuntu 14.04.4 LTS
- Kernel: Linux 3.13.0-57-generic x86_64
- Load Average: 0.00 0.01 0.06
- Uptime: 0 days, 0 hours, 56 minutes, 12 seconds
- OS Updates: 7 (updates available!)
- OS APT Last Update: 12.06.2016 09:59:51 EDT -04:00:00
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
CPU MHz: 2399.998
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: B/490.03 MB in use (%)
- SWAP: B/ B in use (%)
- DISK: 2.25 GB/16.28 GB in use (13%)
> libglib: 2.40.2-0ubuntu1
- Binary: /opt/ts3soundboard/sinusbot (Hash: a48069da6b637c88fceb92244e8df116)
- Version: 0.9.11-6e331b1
- Bot Plugin: d1ddcca9fd7ace3caf85821656b425c2
- TS3 Client: d1ddcca9fd7ace3caf85821656b425c2
- YoutubeDLPath = not set
- Report date: 12.06.2016 10:27:15 EDT -04:00:00 (timezone: America/New_York)
- youtube-dl Version: unknown
- DiagScript version: 0.4.5
