Solved Sinusbot starts and stopps instantly
LeonPlayzz
So, my problem is that my Bot is starting and stopping instantly..
I'm running Sinusbot on version 1.0.0-beta.5-b262b6a and my TeamSpeak 3 server on version 3.9.1.
I've installed sinusbot by using the install script from https://sinusbot-installer.de/.
My Server and the bot is running on Linux Debian 9.0 (64bit) minimal
The server is Running with 4 Cores and 6GB RAM
If you need any further Information just ask for them and i'll send answer you.
Linux srv53530 2.6.32-openvz-042stab128.2-amd64 #1 SMP Thu Mar 22 11:00:12 MSK 2 018 x86_64 GNU/Linux
- Operating System: Debian GNU/Linux 9.11 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-openvz-042stab128.2-amd64 x86_64
- Load Average: 0.15 0.06 0.03
- Uptime: 1 days, 12 hours, 28 minutes, 52 seconds
- OS APT Last Update: 28.10.2019 00:23:40 UTC +00:00:00
- Shell Locale: (not set)
- RAM: B/6.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 1.66 GB/147.51 GB in use (1%)
- libglib: 2.50.3-2+deb9u1
- Status: running (PIDs: 8245 8244, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.10.29)
linux-vdso.so.1 (0x00007ffd6111f000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fc20587c000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fc205524000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fc205123000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fc2047be000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fc20454a000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc204346000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fc204042000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc203e25000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fc203aa3000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fc20388c000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc2034ed000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc2032d3000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fc2030cb000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc205a96000)
- Time (local): 29.10.2019 12:48:41 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2019.10.29
Hope you can find the Solution for my Problem.
Sincerely
LeonPlayzz | Leon
