Solved SinusBot web interface under Apache
Androrel
First of all sorry if this thread is not in the right section of this forum.
I want to know if the web interface can run under Apache.
Thanks for this amazing soft, big up to the team :)
Regards, Androrel.
Version 0.9.8 running on:
Debian 7 or Ubuntu 14.10 (get both x64)
1 vCore
2,4 GHz
2 Go RAM
SSD 10 Go
Regards, Androrel.
1 vCore
2,4 GHz
2 Go RAM
SSD 10 Go
Heyho ;)
Like kanalumaddela said you can use NGINX / APACHE MOD Proxy for this. I prefer nginx.
Also you have an Option in your config.ini -> IsProxied=false if you use a Reverse proxy in front of your bot set it to true to get the right Client IP Adresses in your logs :)
