test
xGuard
i have already reinstalled the sinusbot 10 times nothing helps
  • Sinusbot newest version
  • Ubuntu 18.04
  • VPS on OVH 2 GB
LicenseKey = "ygOhJXAhPft0GZcvMZlfFY6wJlpKbcBxiQpinrnqX0w="
  ChunkSize = 5242880
Error Code
2018/07/01 18:52:59 e4b274c7 a849a004 WARN   Could not create Chat-Tabletable Chat already exists
2018/07/01 18:52:59 e4b274c7 a849a004 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/07/01 18:52:59 e4b274c7 a849a004 WARN   Could not create Notifications-Tabletable Notifications already exists
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  Could not delete from FileTransferno such table: FileTransfer
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  Could not delete from Newsno such table: News
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  Could not insert into News-Tableno such table: News
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   Starting instance ts3server://ts.grajownia.pl?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2018/07/01 18:52:59 X [MAIN] New connection
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  TS>Crashdump ENABLED,  directory is: /opt/sinusbot/data/ts3/e4b274c7-dc7b-4f51-9074-773ff3eba08b/a849a004-e19c-47c5-a374-ccad381e82c4/crashdumps
2018/07/01 18:52:59 e4b274c7 a849a004 DEBUG  TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/e4b274c7-dc7b-4f51-9074-773ff3eba08b/a849a004-e19c-47c5-a374-ccad381e82c4/crashdumps
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.1.10 (2018-06-09 09:46:55)
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |              |   |SystemInformation: Linux 4.15.0-23-generic #25-Ubuntu SMP Wed May 23 18:02:16 UTC 2018 x86_64 Binary: 64bit
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |              |   |Using hardware aes
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |DEBUG   |PulseAudio    |   |connected to pulse audio server -
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |              |   |successfully downloaded revocation list
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2018/07/01 18:52:59 e4b274c7 a849a004 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>The X11 connection broke: I/O error (code 1)
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>XIO:  fatal IO error 2 (No such file or directory) on X server "unix/:40.0"
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  TS>      after 211 requests (207 known processed) with 0 events remaining.
2018/07/01 18:53:00 e4b274c7 a849a004 DEBUG  Closed.
2018/07/01 18:53:00 e4b274c7 a849a004 INFO   TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2018/07/01 18:53:24 e4b274c7 a849a004 DEBUG  Storing configuration.
