Trying to start bot
ygtripps
So when I try to start my bot I keep getting this. I am currently running my bot on the same system with Ubuntu 14.04 and the latest version of both teamspeak and sinusbot.
2015/09/09 22:38:33 e71c2edc f169e5e1 WARN   Could not delete from Profilesno such table: Profiles
2015/09/09 22:38:33 e71c2edc f169e5e1 WARN   Could not insert into Profiles-Tableno such table: Profiles
2015/09/09 22:38:33 e71c2edc f169e5e1 INFO   Starting instance ts3server://kbve.com?port=9987&nickname=Kbve.com%20Bot&password=&channel=&channelpassword=
2015/09/09 22:38:33 e71c2edc f169e5e1 INFO   TSClient quit.
ygtripps
That is the thing, I have tried running it in either of those modes, it does not work.
When I run "LC_ALL="en_US.UTF-8" xinit /home/ts3-web/music/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac"
I get that message everytime the bot runs.
When I run "xinit /home/ts3-web/music/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac" I get this message
bot@nodejs:~$ xinit /home/ts3-web/music/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension GLX
[dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
/home/ts3-web/music/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libQt5Core.so.5: cannot open shared object file: No such file or directory
Run: export LD_LIBRARY_PATH=/path/to/ts3/client
then try again :)
