GuepardHD
Hello, I use the script https://sinusbot-installer.de and yesterday I did the update and so it put the latest version of sinusbot and the client in 3.3.0 and when I try to connect the bot to my teamspeak it does not work i use a linux debian 8 64 bit so i think the client version is not compatible with sinusbot.
- Kernel: Linux 3.16.0-7-amd64 x86_64
- Load Average: 0.00 0.01 0.02
- Uptime: 1 days, 0 hours, 0 minutes, 47 seconds
- OS APT Last Update: 25.07.2019 17:01:27 CEST +02:00:00
- Shell Locale: fr_FR.UTF-8
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model name: Intel Core Processor (Haswell, no TSX)
CPU MHz: 2394.454
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 206.49 MB/1.91 GB in use (10%)
- DISK: 1.70 GB/19.62 GB in use (8%)
- libglib: 2.42.1-1+deb8u1
- Status: running (PIDs: 10856 10853, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.07.16)
linux-vdso.so.1 (0x00007ffe5b1e1000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f1f0448f000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f1f04137000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f1f03d36000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f1f033d1000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f1f0315d000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f1f02f59000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1f02c58000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1f02a3b000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1f02730000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1f0251a000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1f0216f000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f1f01f54000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1f01d4c000)
/lib64/ld-linux-x86-64.so.2 (0x00007f1f046a9000)
- Time (local): 25.07.2019 17:24:28 CEST +02:00:00
- Time (remote): 25.07.2019 17:24:28 CEST +02:00:00
- Timezone:
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.16
