TS3Client quit / no sound from bot
Hello i had problem when i start playing music or grant talk power on bot TS3Client quits. now i fixed it by installing pulseaudio but now i don't have sound out of bots.
whats causing a problem?
___ ___ _ _ _ _ ___ ___ ___ _____
Version: 1.0.0-beta.5-b262b6a
2019/12/06 22:10:12 d8e1cc1b INFO Loading instances
2019/12/06 22:10:12 d8e1cc1b INFO Loading instance://2641adc7-34b1-42bd-affd-8be6a37414fd
2019/12/06 22:10:12 d8e1cc1b 2641adc7 DEBUG executing script command
2019/12/06 22:10:12 d8e1cc1b 2641adc7 INFO Initialization complete
2019/12/06 22:10:12 d8e1cc1b 2641adc7 INFO Auto-Starting d8e1cc1b-2509-4ad8-9edf-e78387750a09/2641adc7-34b1-42bd-affd-8be6a37414fd in 500 ms...
2019/12/06 22:10:12 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/12/06 22:10:12 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/12/06 22:10:12 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/12/06 22:10:12 d8e1cc1b 2641adc7 DEBUG registered callback for event chat
2019/12/06 22:10:12 d8e1cc1b 2641adc7 DEBUG module registered as command
2019/12/06 22:10:12 d8e1cc1b 2641adc7 INFO script command loaded
2019/12/06 22:10:12 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/12/06 22:10:13 d8e1cc1b 2641adc7 DEBUG Prespawn.
2019/12/06 22:10:13 d8e1cc1b 2641adc7 DEBUG About to run.
2019/12/06 22:10:13 d8e1cc1b 2641adc7 WARN Could not create Chat-Tabletable Chat already exists
2019/12/06 22:10:13 d8e1cc1b 2641adc7 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/12/06 22:10:13 d8e1cc1b 2641adc7 WARN Could not create Notifications-Tabletable Notifications already exists
2019/12/06 22:10:13 d8e1cc1b 2641adc7 DEBUG Could not delete from FileTransferno such table: FileTransfer
2019/12/06 22:10:13 d8e1cc1b 2641adc7 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/12/06 22:10:13 [GENERAL/RADIO ] INFO Imported radio stations
2019/12/06 22:10:13 d8e1cc1b 2641adc7 INFO Starting instance ts3server://teamspeak.rs?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/12/06 22:10:13 X [MAIN] New connection
2019/12/06 22:10:14 d8e1cc1b 2641adc7 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/d8e1cc1b-2509-4ad8-9edf-e78387750a09/2641adc7-34b1-42bd-affd-8be6a37414fd/crashdumps
2019/12/06 22:10:14 d8e1cc1b 2641adc7 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/d8e1cc1b-2509-4ad8-9edf-e78387750a09/2641adc7-34b1-42bd-affd-8be6a37414fd/crashdumps
2019/12/06 22:10:14 X [MAIN] New connection
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |SystemInformation: Linux 4.15.0-72-generic #81-Ubuntu SMP Tue Nov 26 12:20:02 UTC 2019 x86_64 Binary: 64bit
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |DEBUG |PulseAudio | |connected to pulse audio server -
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |Addons | |Checking for addon updates...
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |successfully downloaded revocation list for accounting
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |*** Time [MAINWINDOW]: 306
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO | | |*** Time [INIT]: 306
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |Qt version: 5.12.1
2019/12/06 22:10:14 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/d8e1cc1b-2509-4ad8-9edf-e78387750a09/2641adc7-34b1-42bd-affd-8be6a37414fd/settings.db
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |ts3server: teamspeak.rs?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Connect to server: teamspeak.rs
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Trying to resolve teamspeak.rs
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO | | |Statistics report: Not yet, next report on Tue Dec 24 22:03:42 2019
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.teamspeak.rs" Domain name not found
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |SRV DNS resolve successful, "_ts3._udp.teamspeak.rs" =(h: ts3.roshke.me p:9987)
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "teamspeak.rs" =(h: 104.28.24.209 p:0)
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "teamspeak.rs" =(h: 104.28.24.209 p:0)
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts3.roshke.me" =(h: 164.132.116.56 p:0)
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Lookup finished: ip=164.132.116.56 port=9987 query=teamspeak.rs error=0
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Resolve successful: 164.132.116.56:9987
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Initiating connection: 164.132.116.56:9987
2019/12/06 22:10:15 d8e1cc1b 2641adc7 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO New connection status 1; Error 0
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 8
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Connect status: Connected
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO New connection status 2; Error 0
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO New connection status 3; Error 0
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG PLOJKA joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG MAKI joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG GeGaRa :D joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG asdasdas joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG wasich joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG ivkovic joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG rolex joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG player joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG divine makk1 joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG Dragiev joined the channel
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |INFO |ClientUI |1 |Connect status: Connection established
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO TS |INFO |PermManager | |Loading permissions from cache
2019/12/06 22:10:16 d8e1cc1b 2641adc7 INFO New connection status 4; Error 0
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Dobrodosao SinusBot!
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG 2568/insufficient client permissions/i_channel_needed_description_view_power
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Prvi put si posetio nas server 2019-12-06 23:03:45.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Ovo je tvoja 3 konekcija.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Vas uniq id "PrKGKrkAw1pmoy4nIOvC4+5FZo8=".
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Vasa verzija client-a 3.3.0 (2019-06-18 11:29:01) (Linux).
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Vasa ip adresa 31.45.194.118 (HR).
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Ukoliko vam je potrebna pomoc ili imate zalbe/primedbe/predloge/pohvale udjite u kanal "Potrebna pomoc?" i sacekajte administratora.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Welcome SinusBot!
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Your first connection was at 2019-12-06 23:03:45.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> This is your 3 connection.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Your uniq id "PrKGKrkAw1pmoy4nIOvC4+5FZo8=".
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Your client version 3.3.0 (2019-06-18 11:29:01) (Linux).
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Your ip address 31.45.194.118 (HR).
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> If you need help or have any complaints/remarks/suggestions/compliments join in "Need help?" channel and wait for administrator.
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> Facebook Telegram Steam Site
2019/12/06 22:10:16 d8e1cc1b 2641adc7 DEBUG TS> teamspeak.rs administration
2019/12/06 22:10:17 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |TSDNS queried unsuccessfully 104.28.24.209:41144
2019/12/06 22:10:17 d8e1cc1b 2641adc7 INFO TS |INFO |TSDNS | |No TSDNS found
2019/12/06 22:10:18 d8e1cc1b 2641adc7 DEBUG 2568/insufficient client permissions/i_channel_needed_description_view_power
2019/12/06 22:10:18 d8e1cc1b 2641adc7 DEBUG budalica joined the channel
2019/12/06 22:10:29 d8e1cc1b 2641adc7 DEBUG TS> Linux owner 4.15.0-72-generic #81-Ubuntu SMP Tue Nov 26 12:20:02 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
2019/12/06 22:10:30 d8e1cc1b 2641adc7 INFO PRIVATE-CHAT [Hector] yt https://www.youtube.com/watch?v=mTwjUE60HG4
2019/12/06 22:10:30 d8e1cc1b 2641adc7 INFO CHAT 1 [admin @ Hector] < yt https://www.youtube.com/watch?v=mTwjUE60HG4 > / OK
2019/12/06 22:10:30 d8e1cc1b 2641adc7 DEBUG Done playing
2019/12/06 22:10:41 d8e1cc1b 2641adc7 INFO PRIVATE-CHAT [Hector] yt https://www.youtube.com/watch?v=mTwjUE60HG4
2019/12/06 22:10:41 d8e1cc1b 2641adc7 INFO CHAT 1 [admin @ Hector] < yt https://www.youtube.com/watch?v=mTwjUE60HG4 > / OK
2019/12/06 22:10:41 d8e1cc1b 2641adc7 DEBUG Done playing
2019/12/06 22:10:42 d8e1cc1b 2641adc7 DEBUG Storing configuration.
2019/12/06 22:10:46 d8e1cc1b 2641adc7 DEBUG Harryson joined the channel
<23:10:23> "Hector": sinusbot@owneropt/sinusbot$ uname -a
Linux owner 4.15.0-72-generic #81-Ubuntu SMP Tue Nov 26 12:202 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
root@owner:/home/owner# apt-get install -y x11vnc xvfb libxcursor1 ca-certificates bzip2 libnss3 libegl1-mesa x11-xkb-utils libasound2 libpci3 libxslt1.1 libxkbcommon0 curl libglib2.0-0
Reading package lists... Done
Building dependency tree
ca-certificates is already the newest version (20180409).
libxcursor1 is already the newest version (1:1.1.15-1).
x11vnc is already the newest version (0.9.13-3).
bzip2 is already the newest version (1.0.6-8.1ubuntu0.2).
curl is already the newest version (7.58.0-2ubuntu3.8).
libasound2 is already the newest version (1.1.3-5ubuntu0.2).
libegl1-mesa is already the newest version (19.0.8-0ubuntu0~18.04.3).
libglib2.0-0 is already the newest version (2.56.4-0ubuntu0.18.04.4).
libnss3 is already the newest version (2:3.35-2ubuntu2.5).
libpci3 is already the newest version (1:3.5.2-1ubuntu1.1).
libxkbcommon0 is already the newest version (0.8.2-1~ubuntu18.04.1).
libxslt1.1 is already the newest version (1.1.29-5ubuntu0.2).
x11-xkb-utils is already the newest version (7.7+3ubuntu0.18.04.1).
xvfb is already the newest version (2:1.19.6-1ubuntu4.3).
0 upgraded, 0 newly installed, 0 to remove and 49 not upgraded.
I installed BETA 1 Version and this is the error i think it gives me this now.
2019/12/06 23:12:11 6b667668 8581e3b8 INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.pa.dummy.playbackdefault
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.pa.dummy.capturedefault
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 10
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |INFO |ClientUI |1 |Connect status: Connected
2019/12/06 23:12:12 6b667668 8581e3b8 INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019/12/06 23:12:13 6b667668 8581e3b8 INFO TS |INFO |ClientUI |1 |Connect status: Connection established
2019/12/06 23:12:13 6b667668 8581e3b8 INFO TS |INFO |PermManager | |Loading permissions from cache
2019/12/06 23:12:13 6b667668 8581e3b8 INFO TS |INFO |TSDNS | |TSDNS queried unsuccessfully 104.28.25.209:41144
2019/12/06 23:12:13 6b667668 8581e3b8 INFO TS |INFO |TSDNS | |No TSDNS found
2019/12/06 23:12:23 6b667668 8581e3b8 INFO TS |DEBUG |PulseAudio | |Underflow occurred on device ts3.pa.dummy.playbackdefault -
2019/12/06 23:12:23 X [MAIN] New connection
2019/12/06 23:12:24 6b667668 8581e3b8 INFO TSClient quit.
