This is a guide for people who are interested to write sinusbot scripts with typescript.
AS A SIDE NOTE: Typescript typings are still under development and not 100% finnished
you can get the typings from a seperate branch from the scripting-docs repo on github: https://github.com/SinusBot/scripting-docs/tree/typescript
Installation
open the created
and set the option
the file now looks something like this:
now create the file where you actually intend to write your script
`touch example.ts`
and add the following boilerplate code
Note: the first tripple slash comment is very important, it tells typescript from where to load the initial global typings!
when you want to generate js code out of it you can simple run the command
To import typings which are not directly accessible you can use:
all interface declarations can be found in the folder
Installation
		Bash:
	# create a new folder and switch into it
mkdir sinusbot-ts-example
cd sinusbot-ts-example
# initialze npm
npm init
# install typescript and the typings directly from github
npm install --save-dev typescript sinusbot/scripting-docs#typescript
# initialize typescript with an empty tsconfig
npx tsc --initopen the created
tsconfig.jsonand set the option
target to "target": "es2020", and lib the option lib to "lib": ["es2020"],the file now looks something like this:
		JSON:
  "compilerOptions": {
    /* Basic Options */
    // "incremental": true,                   /* Enable incremental compilation */
    "target": "es2020",                          /* Specify ECMAScript target version: 'ES3' (default), 'ES5', 'ES2015', 'ES2016', 'ES2017', 'ES2018', 'ES2019' or 'ESNEXT'. */
    //"module": "commonjs",                   /* Specify module code generation: 'none', 'commonjs', 'amd', 'system', 'umd', 'es2015', or 'ESNext'. */
    "lib": ["es2020"],                        /* Specify library files to be included in the compilation. */
    // "allowJs": true,                       /* Allow javascript files to be compiled. */
    // "checkJs": true,                       /* Report errors in .js files. */
    // "jsx": "preserve",                     /* Specify JSX code generation: 'preserve', 'react-native', or 'react'. */
    // "declaration": true,                   /* Generates corresponding '.d.ts' file. */
    // "declarationMap": true,                /* Generates a sourcemap for each corresponding '.d.ts' file. */
    // "sourceMap": true,                     /* Generates corresponding '.map' file. */
    // "outFile": "./",                       /* Concatenate and emit output to single file. */
    // "outDir": "./",                        /* Redirect output structure to the directory. */
    // "rootDir": "./",                       /* Specify the root directory of input files. Use to control the output directory structure with --outDir. */
    // "composite": true,                     /* Enable project compilation */
    // "tsBuildInfoFile": "./",               /* Specify file to store incremental compilation information */
    // "removeComments": true,                /* Do not emit comments to output. */
    // "noEmit": true,                        /* Do not emit outputs. */
    // "importHelpers": true,                 /* Import emit helpers from 'tslib'. */
    // "downlevelIteration": true,            /* Provide full support for iterables in 'for-of', spread, and destructuring when targeting 'ES5' or 'ES3'. */
    // "isolatedModules": true,               /* Transpile each file as a separate module (similar to 'ts.transpileModule'). */
    /* Strict Type-Checking Options */
    "strict": true,                           /* Enable all strict type-checking options. */
    // "noImplicitAny": true,                 /* Raise error on expressions and declarations with an implied 'any' type. */
    // "strictNullChecks": true,              /* Enable strict null checks. */
    // "strictFunctionTypes": true,           /* Enable strict checking of function types. */
    // "strictBindCallApply": true,           /* Enable strict 'bind', 'call', and 'apply' methods on functions. */
    // "strictPropertyInitialization": true,  /* Enable strict checking of property initialization in classes. */
    // "noImplicitThis": true,                /* Raise error on 'this' expressions with an implied 'any' type. */
    // "alwaysStrict": true,                  /* Parse in strict mode and emit "use strict" for each source file. */
    /* Additional Checks */
    // "noUnusedLocals": true,                /* Report errors on unused locals. */
    // "noUnusedParameters": true,            /* Report errors on unused parameters. */
    // "noImplicitReturns": true,             /* Report error when not all code paths in function return a value. */
    // "noFallthroughCasesInSwitch": true,    /* Report errors for fallthrough cases in switch statement. */
    /* Module Resolution Options */
    // "moduleResolution": "node",            /* Specify module resolution strategy: 'node' (Node.js) or 'classic' (TypeScript pre-1.6). */
    // "baseUrl": "./",                       /* Base directory to resolve non-absolute module names. */
    // "paths": {},                           /* A series of entries which re-map imports to lookup locations relative to the 'baseUrl'. */
    // "rootDirs": [],                        /* List of root folders whose combined content represents the structure of the project at runtime. */
    // "typeRoots": [],                       /* List of folders to include type definitions from. */
    // "types": [],                           /* Type declaration files to be included in compilation. */
    // "allowSyntheticDefaultImports": true,  /* Allow default imports from modules with no default export. This does not affect code emit, just typechecking. */
    //"esModuleInterop": true                 /* Enables emit interoperability between CommonJS and ES Modules via creation of namespace objects for all imports. Implies 'allowSyntheticDefaultImports'. */
    // "preserveSymlinks": true,              /* Do not resolve the real path of symlinks. */
    // "allowUmdGlobalAccess": true,          /* Allow accessing UMD globals from modules. */
    /* Source Map Options */
    // "sourceRoot": "",                      /* Specify the location where debugger should locate TypeScript files instead of source locations. */
    // "mapRoot": "",                         /* Specify the location where debugger should locate map files instead of generated locations. */
    // "inlineSourceMap": true,               /* Emit a single file with source maps instead of having a separate file. */
    // "inlineSources": true,                 /* Emit the source alongside the sourcemaps within a single file; requires '--inlineSourceMap' or '--sourceMap' to be set. */
    /* Experimental Options */
    // "experimentalDecorators": true,        /* Enables experimental support for ES7 decorators. */
    // "emitDecoratorMetadata": true,         /* Enables experimental support for emitting type metadata for decorators. */
}now create the file where you actually intend to write your script
`touch example.ts`
		JavaScript:
	///<reference path="node_modules/sinusbot/typings/global.d.ts" />
registerPlugin({
  "name": "TypeScript Example",
  "description": "a brief description of what this script does",
  "version": "1.0.0",
  "author": "YourName",
  "backends": [],
  "vars": []
  const engine = require("engine")
  engine.log("Hello World!")
})Note: the first tripple slash comment is very important, it tells typescript from where to load the initial global typings!
tsc and you should be doneTo import typings which are not directly accessible you can use:
	import { Client } from "sinusbot/typings/interfaces/Client"all interface declarations can be found in the folder
