Update to alpha 1.0.0 not wrking.
JarwiX
This is my config:
LogLevel = 3
LicenseKey = "XXXXX"
V1 = ""
V2 = ""
Can you tell my why i can't update my bot to 1.0.0-alpha.6?After executing curl -0 https://www.sinusbot.com/pre/sinusbot-1.0.0-alph.6-a47ac17.tar.bz2 console start doing crazy. Something like this.
▒Z*▒t▒▒j▒▒▒z▒ ▒U▒3▒▒54▒I7c/ig
wL[Y▒6p=_▒׷▒)▒▒ofl▒6▒▒>▒▒▒Y▒▒▒▒▒{▒▒G▒ֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒m▒kZֵ▒kZֵ▒o}▒▒x▒UUUUUUUUUUUUUU_▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZֵ▒kZ▒kZֵ▒kZֵ▒kZֵ▒▒ ▒▒▒▒▒Ӏ\?M▒▒qa▒▒?D▒▒G0p▒"D▒=T>_▒J,[▒▒▒\▒IK▒·O▒▒▒▒h]SHM▒JK@a▒3_▒e▒▒P[▒▒R_CƷ▒▒=▒]▒e▒kA\▒▒▒▒ؽ▒▒▒▒@qP▒*▒>{▒▒▒▒_▒q▒:▒▒▒▒▒;▒▒ߎ /w▒~(▒ 8▒5-O{L)▒
▒▒▒'▒[i8▒▒G▒▒Y'▒R▒▒+-▒▒Pl▒▒▒2▒C.^▒▒0Ʀ▒i▒P▒▒_J▒1ϗ▒j▒$|▒▒h▒Z▒▒Y▒▒▒F▒tpmI$x▒▒+n▒>j
▒C
#▒▒"▒▒yF▒\wS▒Δ▒{▒.▒d▒
▒▒▒T▒▒G)▒▒▒▒s▒ʹrl9▒S�w▒M▒▒▒▒!▒}▒|U▒v▒▒▒c=▒▒▒`t▒
▒▒WЩ▒|▒R▒▒<T▒▒^8Z▒▒ꗳ▒W:▒<?ݤ=▒U?ь▒S▒▒G▒▒"▒▒▒▒▒sdC▒▒|▒g▒+e▒߈1▒▒F▒▒,▒pг▒▒'4▒Bܰtr▒▒▒▒s▒▒▒▒▒N▒8Q▒▒▒▒▒▒▒▒k▒N▒7▒-N▒P▒I▒▒//贷h?'▒▒_ q▒A Vd▒mYPuTTYiHY▒_▒e▒▒A▒▒▒\▒51#▒s▒l5<▒▒?▒▒▒▒eQS▒▒▒ޛ2_▒%f^▒m▒t▒▒▒▒ i3D9▒▒*N▒X▒▒▒Vu▒▒-t▒>oMKE▒~▒▒,S2▒h▒q߽▒E▒T▒*▒b,▒'▒▒▒▒▒M`▒e▒▒cOw {▒C▒▒▒N▒▒▒▒▒-T▒▒@.▒H▒t▒▒SS▒Y▒MH▒▒3ʤ_E3=11
What can i do with it?
It should be curl -O ... and not curl -0 ... (so O instead of 0!).
Just copy and paste next time...
JarwiX
Thank you so much but i can't unzip file. Why?
/opt/sinusbot# tar -xjvf sinusbot-1.0.0-alph.6-a47ac17.tar.bz2
bzip2: (stdin) is not a bzip2 file.
tar: Child returned status 2
tar: Error is not recoverable: exiting now
JarwiX
Is this bad joke or what?
bzip2: Compressed file ends unexpectedly;
perhaps it is corrupted? *Possible* reason follows.
bzip2: Inappropriate ioctl for device
Input file = (stdin), output file = (stdout)
It is possible that the compressed file(s) have become corrupted.
You can use the -tvv option to test integrity of such files.
You can use the `bzip2recover' program to attempt to recover
data from undamaged sections of corrupted files.
root@vmi240540:/opt/sinusbot# ^C
root@vmi240540:/opt/sinusbot# tar -tvv sinusbot-1.0.0-alpha.6-a47ac17.tar.bz2
tar: Refusing to read archive contents from terminal (missing -f option?)
- No, it's not. I rather feel joked by you.
- This line there is missing the A in "alpha", but otherwise the command would be correct to execute. But I guess you are not even executing it.
- So that command are you executing? Here the filename is correct (alpha ✅) but your param of the tar cmd is wrong. Not "-tvv" but use "-xjvf" as stated above.
