EN Volume control in TeamSpeak
v4riant
I am looking for a script that basically makes it so anyone in the same channel as the bot can do a command that will specify the volume of the bot. Inside the SinusBot control panel you can adjust the volume between 0 and 100 so this script would just do that but inside teamspeak with a command. For example "!vol {number between 0 and 100}"
