Which anti-captcha solution works best for automated scripts?
Inamorat
Guys, can you recommend which anti-captcha service is best to integrate into my script? The site added protection and now my parser doesn't work. Need something automatic that solves captchas by itself. What actually works and is worth the money?
Most anti-captcha services work by sending the captcha to their API and receiving the solved result, but quality and speed vary between providers. The main things to look for are high accuracy rates, fast response times, reliable uptime, and good API documentation for easy integration. Some services specialize in specific types while others handle a broader range, and most provide libraries for popular programming languages with straightforward implementation. You'll want to add proper error handling since solving can occasionally fail and you might need retry logic. You can use this service for captcha solving: https://captchathecat.com/. This platform offers reliable automated solving that integrates well with scripts and handles various types efficiently.
