Youtube DL Problem
Dimarzio
I use sinusbot for 1 year and i got no problems, but today the !yt command stop working i dont know why.
when i use !yt link it just say downloading but doesnt play the song. If i go to Upload in my sinusbot panel and add the link then Add Job it appears the link but it shows this message:
unable to download video data: urlopen error [Errno 99] Cannot assign requested address
I try everything on my config.ini i read the FAQ but nothing helps
DataDir = "/home/sinusbot/data/"
YouTubeDLPath = "/usr/local/bin/youtube-dl"
LicenseKey = "UAVgaGrLBG8hY1sBemgQHAlm4E0rYmun1oUtJm/7TEM="
[YouTubeDL]
UserAgent = "SinusBot (0.9.12.3-5b7c0cd)"
DerSandmann
A Way to install and Update the Youtube-dl is this one:
apt-get install python-pip
pip install youtube_dl
and update
pip install youtube_dl --upgrade
And try to update your sinusbot/ts3bot there some better and newer one
Dimarzio
i already have the latest version of youtube dl, idk if my sinusbot is at the latest version but i have this one SinusBot (0.9.12.3-5b7c0cd)
Dimarzio
Nope i just install it watching this tutorial
and everything works good just when i use !yt command it says downloading but nothing happens
DerSandmann
ok try to reinstall the bot and the youtube-dl and try it
or lock if the bot/youtube-dl have the rights to download
Dimarzio
Ok i fix it the problem was the YouTubeDLPath = "/usr/local/bin/youtube-dl" i just change it to this YoutubeDLPath = "/usr/local/bin/youtube-dl" and this one [YouTubeDL] to this [YoutubeDL] is downloading and running perfectly thanks for your time :)
