A little problem.
Youssef
Well, i used sinusbot on my VPS server and all works good, i added instance to another server that is not on the VPS, it worked great, after 2 days i just have this message.
2016-06-05T15:17:23+03:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist or the password is wrong or the security level of your identity is too low.
Well, i don't think that the problem from channel or password
What i need to know how to fix
1)This might have several reasons: the server doesn't exist at that address.
2)The security level of your identity is too low.
With steps kindly.
Thanks.
Sorry, but that says all. Additional you could be sure, that your Bot is running on the latest version (Beta).
Your Server (or Server Hoster) is using a valid license and your IP ist not Grey or Blacklisted? ;)
This is currently one of the most reasons for such a behavior, the Greylist popup blocks the Bot while connecting.
For that you must contact Teamspeak.com.
ShadowFM
Your Server used a invalid license. I think your server is currently not blacklisted.
Which client version do you use for your bot?
iTaskmanager
Tier II
Tier I
I have looked at the problem. It was probably due to the firewall from the hosting-provider.
If the issue resolved with the firewall and it still doesn't work, you can always contact me.
