So SinusBot was working fine when I restarted the VPS due of SinusBot Lag (The Bot had about 20d Uptime) and when I try starting it again it says: a manual update is available. The thing is that my VPS does has a very low version of Kernel and it is only compatible with the TS3 Version 3.1.10 so I need to install the SinusBot 1.0 Beta2
- SinusBot 1.0 Beta2
- TS3 Client: 3.1.10 | TS3 Version: 3.7.1
- OS: Debian 9.9 Stretch
- Specs: 1 Core, 1 GB, 15 GB Space
- Instance Log:
___ ___ _ _ _ _ ___ ___ ___ _____ / __|_ _| \| | | | / __| _ )/ _ \_ _| \__ \| || .` | |_| \__ \ _ \ (_) || | |___/___|_|\_|\___/|___/___/\___/ |_| Version: 1.0.0-beta.2-63286de (C) 2013-2019 Michael Friese. All rights reserved. a manual update is required
- Config.ini:
Code:TS3Path = "/opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64" ListenHost = "0.0.0.0" DataDir = "/opt/sinusbot/data/" ListenPort = 8087 LocalPlayback = false EnableLocalFS = false MaxBulkOperations = 300 LogLevel = 10 EnableProfiler = false YoutubeDLPath = "/opt/sinusbot/youtube-dl" EnableDebugConsole = false AllowStreamPush = false UploadLimit = 83886080 RunAsUser = 0 RunAsGroup = 0 ExternalFileBase = "" InstanceActionLimit = 6 UseSSL = false SSLKeyFile = "" SSLCertFile = "" Hostname = "" HostnameMask = "" SampleInterval = 60 StartVNC = false EnableWebStream = false LogFile = "" LicenseKey = "FpSrAuNrDi31E6gVFD0dqdhL2GqSyy5sry6ZCNsa4GE=" IsProxied = false DenyStreamURLs = [] Pragma = 0 UserAgent = "" [YoutubeDL] BufferSize = 524288 MaxDownloadSize = 419430400 MaxDownloadRate = 104857600 MaxSimultaneousChunkDownloads = 6 CacheStreamed = false TimeoutSingleDownloader = 0 TimeoutMultiDownloader = 0 ChunkSize = 3145728 [TS3] AvatarMaxWidth = 0 AvatarMaxHeight = 0 AllowGIF = false [StreamRewrites] [Scripts] Debug = false AllowReload = false EnableTimer = false DisableLegacyEvents = false DevMode = false ScriptTimeout = 5 [Themes] Default = "" [SpeechRecognition] Enable = false [FFmpeg] UserAgent = "SinusBot (1.0.0-beta.2-63286de)" WaitTime = 0 [DAV] Enable = false [XServer] Delay = 0 Debug = false [SHMem] Enable = false Size = 0 Delay = 0 Interval = 0 [RadioStations] URL = "" UpdateInterval = 0 [TTS] Enabled = false
- Diag Script:
Code:SINUSBOT RELATED SYSTEM INFORMATION - Operating System: Debian GNU/Linux 9.9 (stretch) (OpenVZ) - Kernel: Linux 2.6.32-042stab134.3 x86_64 - Load Average: 0.00 0.00 0.00 - Uptime: 0 days, 0 hours, 9 minutes, 41 seconds - OS x64 check: OK - OS Updates: 0 (well done!) - OS Missing Packages: None - OS APT Last Update: 12.08.2019 04:07:49 EDT -04:00:00 - Shell Locale: (not set) - Bot Start Script: not found - CPU: (failed retrieving information) - RAM: B/1.00 GB in use (%) - SWAP: B/ B in use (%) - DISK: 1.48 GB/14.63 GB in use (10%) - Package versions: - libglib: 2.50.3-2 BOT INFORMATION - Status: not running - Webinterface: port locally not reachable (Port: 8087) - Binary: /opt/sinusbot/sinusbot - Binary Info: MD5 Hash: 2472b206ad5fa41d71e2ce3923c8be80, Perms: 777, User: sinusbot - Version: 1.0.0-beta.2-63286de - TS3 Plugin: installed (md5 hash match) - Bot Plugin: 59c9a688307aa73af9573029a7625fc5 - TS3 Client: 59c9a688307aa73af9573029a7625fc5 - Config: - LogLevel = 10 (debug log active) - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.10) - YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2019.08.02) - Installed scripts: Reconnect.js; Simple_Custom_Commands.js; Youtube_Search.js; advertising.js; alonemode.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; welcome.js BOT TECHNICAL INFORMATION - File exists: - TS3Client/libqxcb-glx-integration.so: no - LDD output: linux-vdso.so.1 (0x00007ffd60fd7000) libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f9c2af41000) libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f9c2abe9000) libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f9c2a7e8000) libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f9c29e83000) libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f9c29c0f000) libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9c29a02000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9c296fc000) libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9c294df000) libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9c2915d000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9c28f46000) libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9c28ba7000) libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9c2898d000) librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9c28783000) /lib64/ld-linux-x86-64.so.2 (0x00005644eaf61000) REACHABILITY CHECKS - HTTPS check with IPv4 mode: SUCCESS [Connection established to www.sinusbot.com, CODE #200] - HTTPS check with IPv6 mode: IGNORED [Disabled] - DNS resolution check: SUCCESS [www.sinusbot.com resolved to 104.28.15.74] - Update server checks: update01.sinusbot.com -> 104.28.15.74: SUCCESS [CODE #404] update02.sinusbot.com -> 104.28.14.74: SUCCESS [CODE #404] update03.sinusbot.com -> 104.28.15.74: SUCCESS [CODE #404] TIME INFORMATION - Time (local): 12.08.2019 20:19:11 EDT -04:00:00 - Time (remote): <Failed retrieving remote time!> - Time (difference): n/a secs - Timezone: America/New_York OTHER INFORMATION - TeamSpeak3 Version: 3.1.10 (vulnerable! outdated!) - youtube-dl Version: 2019.08.02 - DiagScript Version: 0.8.0 ==========================================================
