Bug Advertising do not work
alexwilliam
Operating System: Linux debian 8
TS3 Version: 3.0.11.2
Good evening, my sinusbot does not launch the script Advertising. The Advertising script does not work can you help me?
I resintaller 3 times my sinusbot and toujorus alike!
thank you
2017-01-17T00:36:14+01:00 Loading script advertising
2017-01-17T00:34:33+01:00 TS |INFO |LicenseViewer | |Downloaded license file for version 1 and language en
2017-01-17T00:34:33+01:00 TS |INFO |LicenseViewer | |Requesting remote license for version 1 and language en
2017-01-17T00:34:33+01:00 TS |INFO |LicenseViewer | |License language: en
2017-01-17T00:34:33+01:00 TS |INFO |Update | |Check license version: 1
2017-01-17T00:34:33+01:00 TS |INFO |Update | |Checking for updates...
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI | |Checking for update
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI | |Last update check was: dim. janv. 1 00:00:01 2017
2017-01-17T00:34:33+01:00 New connection status 4; Error 0
2017-01-17T00:34:33+01:00 TS |INFO |PermManager | |Loading permissions from cache
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-01-17T00:34:33+01:00 New connection status 3; Error 0
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-01-17T00:34:33+01:00 New connection status 2; Error 0
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-01-17T00:34:33+01:00 New connection status 1; Error 0
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-01-17T00:34:33+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2017-01-17T00:34:33+01:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2017-01-17T00:34:33+01:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-01-17T00:34:32+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data//ts3/eb4165f9-be71-4842-b4be-b677886cdc73/49c1a56b-5102-4826-b32a-ff38594cb0f5/settings.db
2017-01-17T00:34:32+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-01-17T00:34:32+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-01-17T00:34:32+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-01-17T00:34:32+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-01-17T00:34:32+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-01-17T00:34:32+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-01-17T00:34:32+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-01-17T00:34:32+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-01-17T00:34:32+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
2017-01-17T00:34:32+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
2017-01-17T00:34:32+01:00 TS |INFO | | |Using hardware aes
2017-01-17T00:34:32+01:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1 (2016-12-30) x86_64 Binary: 64bit
2017-01-17T00:34:32+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-01-17T00:34:32+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-01-17T00:34:11+01:00 Loading script advertising
2017-01-17T00:31:46+01:00 TSClient quit.
2017-01-17T00:31:45+01:00 New connection status 0; Error 0
2017-01-17T00:31:45+01:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2017-01-17T00:31:45+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2017-01-17T00:31:42+01:00 TS |INFO |LicenseViewer | |Downloaded license file for version 1 and language fr
2017-01-17T00:31:41+01:00 TS |INFO |LicenseViewer | |Requesting remote license for version 1 and language fr
2017-01-17T00:31:41+01:00 TS |INFO |LicenseViewer | |License language: fr
2017-01-17T00:31:41+01:00 TS |INFO |Update | |Check license version: 1
2017-01-17T00:31:41+01:00 TS |INFO |Update | |Checking for updates...
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |Checking for update
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |Last update check was: Never
2017-01-17T00:31:41+01:00 New connection status 4; Error 0
2017-01-17T00:31:41+01:00 TS |INFO |PermManager | |Requesting permissions from server
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2017-01-17T00:31:41+01:00 New connection status 3; Error 0
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2017-01-17T00:31:41+01:00 New connection status 2; Error 0
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Connect status: Connected
2017-01-17T00:31:41+01:00 New connection status 1; Error 0
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2017-01-17T00:31:41+01:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Blacklist check ok
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data//ts3/eb4165f9-be71-4842-b4be-b677886cdc73/49c1a56b-5102-4826-b32a-ff38594cb0f5/settings.db
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |Qt version: 5.5.1
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2017-01-17T00:31:41+01:00 TS |INFO |ClientUI | |*** Time [SQLITE_CONVERTER]: 4
2017-01-17T00:31:41+01:00 TS |INFO | | |*** Time [INIT]: 234
2017-01-17T00:31:41+01:00 TS |INFO | | |*** Time [MAINWINDOW]: 233
2017-01-17T00:31:41+01:00 Already online.
2017-01-17T00:31:41+01:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2017-01-17T00:31:41+01:00 TS |INFO | | |Loading plugin: libtest_plugin
2017-01-17T00:31:41+01:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2017-01-17T00:31:41+01:00 TS |INFO | | |Loading plugin: liblua_plugin
2017-01-17T00:31:41+01:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2017-01-17T00:31:40+01:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2017-01-17T00:31:40+01:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
2017-01-17T00:31:40+01:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: Ne peut ouvrir le fichier d'objet partagé: Aucun fichier ou dossier de ce type
2017-01-17T00:31:40+01:00 TS |INFO | | |Using hardware aes
2017-01-17T00:31:40+01:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1 (2016-12-30) x86_64 Binary: 64bit
2017-01-17T00:31:40+01:00 TS |INFO | | |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017-01-17T00:31:40+01:00 Auto-Starting eb4165f9-be71-4842-b4be-b677886cdc73/49c1a56b-5102-4826-b32a-ff38594cb0f5 in 500 ms...
2017-01-17T00:31:40+01:00 Initialization complete
2017-01-17T00:31:40+01:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
