API (not) a bug (POST)
SUNSHINE
I have a bug with the API.
I try this script :
    $sURL = "[URL]http://x:8088/api/v1/bot/login[/URL]"; // The POST URL
    $sPD = "username=admin?password=foobar?botId=1"; // The POST Data
    $aHTTP = array(
     'http' => // The wrapper to be used
        array(
        'method'  => 'POST', // Request Method
        // Request Headers Below
        'header'  => 'Content-type: application/x-www-form-urlencoded',
        'content' => $sPD
    $context = stream_context_create($aHTTP);
    $contents = file_get_contents($sURL, false, $context);
    echo $contents;
He result to an error :
{"success":false,"code":406,"error":"invalid character 'u' looking for beginning of value"}
How to fix ?
Thanks
How to fix ?
Thanks
Read the Documentation, the whole API want's JSON.
You need a other Content Type: application/json
And you need to encode your data as json.
The bot ID is never 1, the Bot ID is a hash (You get it from /api/v1/botId)
https://www.sinusbot.com/api/
for JSON examples, just open the developement tools of google chrome, firefox etc, and check the network traffic
PHP:
$myJson = "{\"mystring\": \"Hello World.\"}";
$array = json_decode($myJson, true);
var_dump($array);
echo json_encode($array);
Can you send me script/screen ? I don't find that.
Ask google, keyword your programming language + JSON. This should not be so hard.
Also there are tons of JSON Validators ;)
SUNSHINE
Can you give me an example with SINUSBOT ? Because actually I don't understand your script, Idk JSON script.
Where I put link ? Parameters ? ..
Very thanks for your help
I linked you the Documentation, the JSON must be sent in the Body. This is basic Programming Knowledge.
I don't know which language you use so i can't help. How i said use google, if you know how it works basicly in your language you know also how it works with the Sinusbot.
SUNSHINE
Okay, I have maked this :
$data = array("username" => "admin", "password" => "foobar", "botId" => "c471f075-c4bc-4f73-8127-20e1a30c98ea");
$data_string = json_encode($data);
$ch = curl_init('http://x:8088/api/v1/bot/login');
curl_setopt($ch, CURLOPT_CUSTOMREQUEST, "POST");
curl_setopt($ch, CURLOPT_POSTFIELDS, $data_string);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
curl_setopt($ch, CURLOPT_HTTPHEADER, array(
    'Content-Type: application/json',
    'Content-Length: ' . strlen($data_string))
$result = curl_exec($ch);
print_r($result);
He return :
What is this "token" ?
I removed the Token, this is your login Token. Required for all other calls.
You need to add this token as Header -> Authorization: bearer YOURTOKENHERE TO ALL OTHER CALLS THEN LOGIN.
SUNSHINE
New error :
$data = array("name" => "test", "password" => "testpass", "tsuid" => "test", "tsgid" => 60, "privileges" => 5);
$token_id = "x";
$ch = curl_init('http://x:8088/api/v1/bot/users');
    "Authorization: bearer $token_id",
print_r($result);
Return : {"success":false,"code":8081,"error":"'name' or 'password' not set"}
But I set "name" and "password" in the array "$data"...
SUNSHINE
Done.
$data = array("name" => "test", "password" => "testpass", "privileges" => 2147483647);
Same error : {"success":false,"code":8081,"error":"'name' or 'password' not set"}
