Audio stream
Lawliz
I would like to have a link that does not change when I use the audio stream.
Basically, I set EnableWebStream to true and SampleInterval to 60 and I would like to recover a link that does not change to use in a game that allows you to put radios.
And I would like this radio to be the sound that passes on the bot teamspeak.
But when I use the api of the bot he give me a different token for a different song and this token is too long.
Do you have an idea?
Cordially. (Sorry for my bad English, I'm French)
Config Server (VPS SSD 3 by OVH) :
2 vCore(s)
2,4 GHz
8 Go de RAM
40 Go SSD
OS : Debian 9
SinusBot Version : SinusBot 0.13.37-9791176
Teamspeak Version : TeamSpeak 3 Client 3.1.9
Scripts lists :
  • AFK Mover(No Idle check)
  • Advanced display playback information
  • Jail
  • Server Join Alert
  • Simple Custom Command
  • WelcomeMessage+
  • Avatar banner for and with SinusBot
  • !come
  • No Recording!
  • Private message or poke to all clients
  • Remember Last Channel
config.ini :
TS3Path = "/opt/rpsbot/teamspeak3-client/ts3client_linux_amd64"
ListenHost = "51.38.232.27"
DataDir = "/opt/rpsbot/data/"
EnableWebStream = true
LicenseKey = "hYqQawQeRDKUu1sqYRRCMqDm4wbVZ++bvHxRrCJzimY="
  ChunkSize = 5242880
  AllowGIF = true
[Scripts.Privileges]
avatarbanner = ["graphics"]
You could just write for example an php script that generates the token and redirects to the URL with that token, so that the URL of your php script is static.
I'll think about adding the possibility to have a fixed token or do something with the internal scripting engine.
