Solved Bekomme den Bot nicht auf meinen TS gestartet.
Nicole Sophie
 - Kernel: Linux 4.19.0-9-amd64 x86_64
 - Load Average: 0.08 0.06 0.07
 - Uptime: 0 days, 9 hours, 33 minutes, 54 seconds
 - OS APT Last Update: 22.05.2020 22:29:23 CEST +02:00:00
 - Shell Locale: en_US.UTF-8
    Architecture:        x86_64
    CPU(s):              2
    Thread(s) per core:  1
    Core(s) per socket:  2
    Socket(s):           1
    Model name:          Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
    CPU MHz:             3200.092
    Hypervisor vendor:   KVM
    Virtualization type: full
 - RAM: 490.99 MB/3.85 GB in use (12%)
 - DISK: 2.18 GB/294.27 GB in use (0%)
   - libglib: 2.58.3-2+deb10u2
 - Status: running (PIDs: 1258 1257, User: sinusbot)
 - Binary Info: MD5 Hash: 224b687db910b732fe5a7cfec4f6c78e, Perms: 777, User: sinusbot
   - TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.5.2)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2020.05.08)
 - Installed scripts: advertising.js; AFK_Mover_(AwayMuteDeafIdle).js; alonemode.js; Auto_Channel_Creator.js; birthday.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; sinusbot-commands.js; welcome.js; WelcomeSound.js
    linux-vdso.so.1 (0x00007ffdf3e98000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f52fae54000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f52faafc000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f52fa6fb000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f52f9d96000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f52f9b22000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f52f9b16000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f52f9991000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f52f9970000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f52f97ec000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f52f97d2000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f52f9611000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f52f93f3000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f52f93e7000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f52fb070000)
 - Time (local): 22.05.2020 23:00:27 CEST +02:00:00
 - Time (remote): 22.05.2020 23:00:27 CEST +02:00:00
 - TeamSpeak3 Version: 3.5.2
 - youtube-dl Version: 2020.05.08
Sinusbot der Browser startet kann die Bots auch erstellen und einstellen nur der will nicht zum TS3-Server Verbinden. Das ist die fehler meldung nach Status abfrage.:
   Active: failed (Result: exit-code) since Fri 2020-05-22 13:28:19 CEST; 9h ago
  Process: 422 ExecStartPre=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
  Process: 425 ExecStart=/opt/sinusbot (code=exited, status=203/EXEC)
  Process: 426 ExecStopPost=/bin/rm -f /tmp/.sinusbot.lock (code=exited, status=0/SUCCESS)
 Main PID: 425 (code=exited, status=203/EXEC)
Und ja Sorry das ich auf Deutsch schreibe, leider bin ich der Englischen Sprache nicht mächtig und Google scheibt teil weise ein totales kaudawelsch.
Bitte mal das LogLevel auf 10 setzen und das Instance-Log dazu posten.
Kannst dazu den Bot am besten mal manuell starten statt den Service.
Der Fehler klingt aber eher danach, als dürfte auch das Webinterface nicht (mehr) gehen ... oder geht es vorher, und dann schmiert er irgendwann ab?
Nicole Sophie
Das Webinterface geht ja. Kann die Playlist erstellen und abspielen lassen nur ebend ohne das der BOT online ist.
Und hier die Instance-Log
2020-05-23T00:29:40+02:00 Storing configuration.
2020-05-23T00:29:26+02:00 closing channels
2020-05-23T00:29:26+02:00 eof from voice
2020-05-23T00:29:25+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-05-23T00:29:25+02:00 Closed.
2020-05-23T00:29:25+02:00 TS>
2020-05-23T00:29:25+02:00 TS>Available platform plugins are: xcb.
2020-05-23T00:29:25+02:00 TS>This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
2020-05-23T00:29:25+02:00 TS>qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
2020-05-23T00:29:25+02:00 TS>qt.qpa.xcb: could not connect to display unix/:40.0
2020-05-23T00:29:25+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-05-23T00:29:25+02:00 Starting instance ts3server://80.241.217.192?port=9987&nickname=EFL-Nicole-Ruhig&password=xxxxx&cid=4&channelpassword=
2020-05-23T00:29:25+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-05-23T00:29:25+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-05-23T00:29:25+02:00 Could not create Notifications-Tabletable Notifications already exists
2020-05-23T00:29:25+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-05-23T00:29:25+02:00 Could not create Chat-Tabletable Chat already exists
2020-05-23T00:29:25+02:00 About to run.
2020-05-23T00:29:25+02:00 Prespawn.
2020-05-23T00:28:40+02:00 Storing configuration.
2020-05-23T00:28:35+02:00 Done playing
2020-05-23T00:28:35+02:00 Channels now zero
2020-05-23T00:28:35+02:00 Deleting channel c7d7910d-13b2-4aaf-b6ea-e33e4e702539 () ID 026a773f-ac51-40cc-ab58-4298e59e71c4 (cc 1)
2020-05-23T00:28:35+02:00 Removing closed channel c7d7910d-13b2-4aaf-b6ea-e33e4e702539 () ID 026a773f-ac51-40cc-ab58-4298e59e71c4
2020-05-23T00:28:35+02:00 Sending stop to c7d7910d-13b2-4aaf-b6ea-e33e4e702539 () ID 026a773f-ac51-40cc-ab58-4298e59e71c4 #1
2020-05-23T00:28:35+02:00 STOP [admin] OK
2020-05-23T00:28:35+02:00 Stopping
2020-05-23T00:28:25+02:00 eof from data
2020-05-23T00:28:25+02:00 closing channels
2020-05-23T00:28:24+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-05-23T00:28:24+02:00 Closed.
2020-05-23T00:28:24+02:00 TS>
2020-05-23T00:28:24+02:00 TS>Available platform plugins are: xcb.
2020-05-23T00:28:24+02:00 TS>This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
2020-05-23T00:28:24+02:00 TS>qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
2020-05-23T00:28:24+02:00 TS>qt.qpa.xcb: could not connect to display unix/:40.0
2020-05-23T00:28:24+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-05-23T00:28:24+02:00 Starting instance ts3server://80.241.217.192?port=9987&nickname=EFL-Nicole-Ruhig&password=xxxxx&cid=4&channelpassword=
2020-05-23T00:28:24+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-05-23T00:28:24+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-05-23T00:28:24+02:00 Could not create Notifications-Tabletable Notifications already exists
2020-05-23T00:28:24+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2020-05-23T00:28:24+02:00 Could not create Chat-Tabletable Chat already exists
2020-05-23T00:28:24+02:00 About to run.
2020-05-23T00:28:24+02:00 Prespawn.
2020-05-23T00:28:10+02:00 Storing configuration.
2020-05-23T00:28:08+02:00 new track info: Josef Klenovský - DIE PUHDYS - ALT WIE EIN BAUM (4a6f736566204b6c656e6f76736bc3bd202d2044494520505548445953202d20414c54205749452045494e204241554d)
2020-05-23T00:28:08+02:00 New channel c7d7910d-13b2-4aaf-b6ea-e33e4e702539 () ID 026a773f-ac51-40cc-ab58-4298e59e71c4 (cc 0)
2020-05-23T00:28:08+02:00 Done playing
2020-05-23T00:28:08+02:00 Channels now zero
2020-05-23T00:28:08+02:00 Deleting channel 9285ede0-cceb-4122-8cd9-3da62c283544 () ID d6425ab8-8359-4192-9fa4-4ecb929e05bd (cc 1)
2020-05-23T00:28:08+02:00 Removing closed channel 9285ede0-cceb-4122-8cd9-3da62c283544 () ID d6425ab8-8359-4192-9fa4-4ecb929e05bd
2020-05-23T00:27:10+02:00 Storing configuration.
2020-05-23T00:27:04+02:00 eof from data
2020-05-23T00:27:04+02:00 closing channels
2020-05-23T00:27:03+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2020-05-23T00:27:03+02:00 Closed.
2020-05-23T00:27:03+02:00 TS>
2020-05-23T00:27:03+02:00 TS>Available platform plugins are: xcb.
2020-05-23T00:27:03+02:00 TS>This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
2020-05-23T00:27:03+02:00 TS>qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
2020-05-23T00:27:03+02:00 TS>qt.qpa.xcb: could not connect to display unix/:40.0
2020-05-23T00:27:03+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2020-05-23T00:27:03+02:00 Starting instance ts3server://80.241.217.192?port=9987&nickname=EFL-Nicole-Ruhig&password=xxxxx&cid=4&channelpassword=
2020-05-23T00:27:03+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2020-05-23T00:27:03+02:00 Could not delete from FileTransferno such table: FileTransfer
2020-05-23T00:27:03+02:00 Could not create Notifications-Tabletable Notifications already exists
fabm3n
Tier II
Tier I
Aktualisiere den TS3 Client mal auf 3.5.3, da wurden nochmal ein paar bugs gefixt (und damit ist der TS Client mal neu installiert falls da was kaputt ist)
PS: Du hast dein TS Server Passwort im Log ;)
Nicole Sophie
Ok haben den Sinusbot einmal komplett neu aufgespielt. jetzt geht er wieder.
Und das mit dem server passwort nicht schlimm ist eh gerade erstmal nur das vorläufige.
bis der ts fertig ist.
