My TSClient quits, it doesnt get connected to
Config:
Diagnostic Script:
Crash log:
Config:
LogLevel = 11
ExternalFileBase = ""
LicenseKey = "*Not needed thing to report*"
DevMode = false
[TTS]
Enabled = false
Diagnostic Script:
- Kernel: Linux 4.9.0-0.bpo.9-amd64 x86_64
- Load Average: 0.06 0.04 0.03
- Uptime: 0 days, 0 hours, 38 minutes, 39 seconds
- OS APT Last Update: 28.07.2019 20:06:47 CEST +02:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 1
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 1
Model name: Intel Core Processor (Haswell, no TSX)
CPU MHz: 2095.076
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 258.17 MB/1.91 GB in use (13%)
- DISK: 2.21 GB/19.62 GB in use (11%)
- libglib: 2.42.1-1+deb8u1
- Status: running (PIDs: 7203 7202, User: sinusbot)
- LogLevel = 11
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.07.27)
linux-vdso.so.1 (0x00007ffe82b55000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f65d9e52000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f65d9afa000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f65d96f9000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f65d8d94000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f65d8b20000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f65d891c000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f65d861b000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f65d83fe000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f65d80f3000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f65d7edd000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f65d7b32000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f65d7917000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f65d770f000)
/lib64/ld-linux-x86-64.so.2 (0x00007f65da06c000)
- Time (local): 28.07.2019 20:26:42 CEST +02:00:00
- Time (remote): 28.07.2019 20:26:42 CEST +02:00:00
- Timezone:
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.07.27
Crash log:
Starting instance ts3server://localhost?port=9987&nickname=SkyBlock&password=&channel=&channelpassword=[1;44r[H[43;149H[1;43r[H[43d
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 X [MAIN] New connection
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/95f073d7-5a01-47d0-96e8-b7e56660b89d/41d753a2-c854-4953-9eac-e66ec935f8aa/crashdumps
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/95f073d7-5a01-47d0-96e8-b7e56660b89d/41d753a2-c854-4953-9eac-e66ec935f8aa/crashdumps
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |INFO | | |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |INFO | | |SystemInformation: Linux 4.9.0-0.bpo.9-amd64 #1 SMP Debian 4.9.168-1+deb9u4~deb8u1 (2019-07-22) x86_64 Binary: 64bit
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |INFO | | |Using hardware aes
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TS |INFO |Addons | |Checking for addon updates...
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2019/07/28 20:30:09 95f073d7 41d753a2 DEBUG Closed.
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:09 95f073d7 41d753a2 INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:10 95f073d7 41d753a2 DEBUG Storing configuration.
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:10 95f073d7 41d753a2 DEBUG closing channels[1;44r[H[43;62H[1;43r[H[43d
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:10 95f073d7 41d753a2 DEBUG eof from data[1;44r[H[43;59H[1;43r[H[43d
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:10 95f073d7 41d753a2 DEBUG eof from voice[1;44r[H[43;60H[1;43r[H[43d
[1;44r[H[43d[1;43r[H[43d2019/07/28 20:30:40 95f073d7 41d753a2 DEBUG Storing configuration.
