Any particular reason you updated to 3.2.5 and not the newest client version (3.3.0) ?
It's unlikely that just the upgrade of the TS-version is causing your problem.
Just get the
beta3, after that update the TS-Client to 3.3.0. (Ofc backup before, so you can do a roll-back)
Then report back, if your problem was solved.
