Niclas2001gamer
Info:
Fehler:
- Operating System: Debian GNU/Linux 9.9 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-openvz-042stab123.9-amd64 x86_64
- Load Average: 0.00 0.03 0.01
- Uptime: 0 days, 0 hours, 44 minutes, 58 seconds
- OS APT Last Update: 29.06.2019 11:45:37 UTC +00:00:00
- Shell Locale: (not set)
- RAM: B/6.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 1.08 GB/59.86 GB in use (1%)
- libglib: 2.50.3-2
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
- YoutubeDLPath = not set
linux-vdso.so.1 (0x00007ffc2956a000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f9d0fdaa000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f9d0fa52000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f9d0f651000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f9d0ecec000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f9d0ea78000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f9d0e86e000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f9d0e568000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f9d0e34b000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f9d0dfc9000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f9d0ddb2000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f9d0da13000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f9d0d7f9000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f9d0d5ef000)
/lib64/ld-linux-x86-64.so.2 (0x00007f9d0ffc6000)
- Time (local): 29.06.2019 12:16:35 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: unknown
Fehler:
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not create Chat-Tabletable Chat already exists
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not create Notifications-Tabletable Notifications already exists
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not delete from Applicationno such table: Application
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not insert into Application-Tableno such table: Application
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG Could not delete from FileTransferno such table: FileTransfer
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not delete from Profilesno such table: Profiles
2019/06/29 12:21:22 2d14eb9f 778a3c7a WARN Could not insert into Profiles-Tableno such table: Profiles
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG Could not delete from Newsno such table: News
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG Could not insert into News-Tableno such table: News
2019/06/29 12:21:22 2d14eb9f 778a3c7a INFO Starting instance ts3server://dayradio.de?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/06/29 12:21:22 X [MAIN] New connection
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019/06/29 12:21:22 2d14eb9f 778a3c7a INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG TS>QStandardPaths: wrong ownership on runtime directory /run/user/0, 0 instead of 1000
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019/06/29 12:21:22 2d14eb9f 778a3c7a DEBUG Closed.
2019/06/29 12:21:23 2d14eb9f 778a3c7a DEBUG closing channels
2019/06/29 12:21:36 2d14eb9f 778a3c7a DEBUG Storing configuration.
