zMasterSkill
Hey, i noticed that my bot just leaves the channel and stops playing every few hours. It still leaves wether someone is in the channel or its empty. I have to restart sinusbot via console again. It appears to be in a kind of "freezed" state. I've attached a log from the console:
![MobaXterm_HfB5uPfOj8.png MobaXterm_HfB5uPfOj8.png](https://forum.sinusbot.com/data/attachments/4/4575-b41d762fb2b19760730982a65890b0dd.jpg)
- Operating System: Debian GNU/Linux 11 (bullseye)
- Kernel: Linux 5.10.0-12-amd64 x86_64
- Load Average: 1.77 1.77 1.71
- Uptime: 23 days, 0 hours, 55 minutes, 11 seconds
- OS Updates: 33 (updates available!)
- OS APT Last Update: 15.11.2022 19:55:59 CET +01:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 6
Thread(s) per core: 1
Core(s) per socket: 6
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2630 v4 @ 2.20GHz
CPU MHz: 2199.996
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 12.28 GB/15.63 GB in use (78%)
- DISK: 18.38 GB/392.61 GB in use (4%)
- libglib: 2.66.8-1
- Status: running (PIDs: 1844837 1844836, User: sinusbot)
- Binary Info: MD5 Hash: 000db57a7fc04074ea799d11281be28a, Perms: 755, User: sinusbot
- Version:
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.5.6)
- YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2021.12.17)
linux-vdso.so.1 (0x00007ffe9f393000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007ff5bff25000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007ff5bfbcd000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007ff5bf7cc000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007ff5bee67000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007ff5bebf3000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007ff5bebe0000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007ff5bea9a000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007ff5bea78000)
libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007ff5be8ab000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007ff5be891000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007ff5be6bc000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007ff5be69f000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007ff5be693000)
/lib64/ld-linux-x86-64.so.2 (0x00007ff5c0141000)
update01.sinusbot.com -> 104.21.13.58: SUCCESS [CODE #404]
- Time (local): 16.11.2022 14:03:53 CET +01:00:00
- Time (remote): 16.11.2022 14:03:53 CET +01:00:00
- TeamSpeak3 Version: 3.5.6
- youtube-dl Version: 2021.12.17
