Solved Bot not connecting
Fuzz3
EDIT: IM USING DEBIAN 7.7 64X
Hi my bot is not connecting i have loglevel=10 my bot tries to connect but it doesnt enter heres the errorss:
those error its from when i start the bot
[dix] Could not init font path element /usr/share/fonts/X11/cyrillic, removing f rom list!
[dix] Could not init font path element /usr/share/fonts/X11/100dpi/:unscaled, re moving from list!
[dix] Could not init font path element /usr/share/fonts/X11/75dpi/:unscaled, rem oving from list!
[dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
[dix] Could not init font path element /usr/share/fonts/X11/100dpi, removing fro m list!
[dix] Could not init font path element /var/lib/defoma/x-ttcidfont-conf.d/dirs/T rueType, removing from list!
and when i try to connect the bot to a teamspeak
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 WARN Could not delete from Profilesno such table: Profiles
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 WARN Could not insert into Profiles-Tableno such table: Profiles
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 DEBUG Could not delete from Notificationsno such table: Notifications
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 DEBUG Could not delete from Newsno such table: News
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 DEBUG Could not insert into News-Tableno such table: News
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 INFO Starting instance ts3server://188.165.55.167?port=51062&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015-09-16 11:08:11.816198|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-09-16 11:08:11.816340|INFO | | | SystemInformation: Linux 3.2.0-4-amd64 #1 SMP Debian 3.2.68-1+deb7u3 x86_64 Binary: 64bit
2015-09-16 11:08:11.816375|INFO | | | Using hardware aes
terminate called after throwing an instance of 'std::runtime_error'
what(): locale::facet::_S_create_c_locale name not valid
2015/09/16 11:08:11 741b0f3b 8e6eb9f3 INFO TSClient quit.
Help me fix thissss fastttt
Fuzz3
DID IT
The problem was with the debian 7.7 64x host
They had a problem with the locales so i wipe the vps put a unbuntu version and bomm it works
fine! ;)
But I only use minimal Images Debian on OpenVZ and the locales can be super easy after installed :) Maybe it's a fault of the Images of your provider.
