bot not starting on vps debian 8
mefek
Hello, i have problem with start my music bot on vps debian 8
i write in console ./sinusbot and have this problem
Horstexplorer
The port is already being used by another application. Try to close the other application or change the port of the sinusbot in the config.
Horstexplorer
Something seem to be with the 'cron-apt' package, you may check your sources.list (/etc/apt/sources.list)
You should follow the steps within the red marked text
I assume you installed your bot with the Installer Script. So in that case I guess your bot is already running in the background. When you manually try to start him with ./sinusbot, you of course get the error shown above.
Use service sinusbot status and please post the output.
