- die benutzte Version: 0.9.8
 - das Betriebssystem Debian 7.8 (amd64)
 - verwendete Hardware: VPS (2 Cores @ 3.4GHz),
 - verwendeter Browser: FF 40.0.3
 - freier Speicher: 94GB Festplattenspeicher (95% belegt); RAM: 718/3965MB
SecretKey = [248, 103, 27, 3, 246, 51, 196, 59, 154, 102, 45, 65, 246, 86, 97, 247, 67, 75, 59, 43, 41, 25, 197, 89, 82, 53, 186, 177, 115, 134, 0, 121]
MTU = 1500
SampleInterval = 100
MTU = 1500
Hallo Leute,
ich habe das Problem, dass nach einem Botneustart die Bots per Webinterface auf keinen Cmd mehr reagieren (kill, Musik abspielen, ...).
Wäre schön, wenn mir bitte jemand helfen könnte.
2015/09/06 18:59:43 e170c668 INFO  Initializing bot://e170c668-7a04-4eff-b683-acaa67de6f64
2015/09/06 18:59:43 e170c668 9e5b958e INFO Loaded
2015/09/06 18:59:43 e170c668 750d8fcd INFO Loaded
2015/09/06 18:59:43 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/09/06 18:59:43 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/09/06 18:59:43 youtube-dl checking...
2015/09/06 18:59:43 youtube-dl version compatible, support enabled
2015/09/06 18:59:44 RadioStation data loaded
2015/09/06 18:59:44 Imported radio stations
2015/09/06 18:59:54 e170c668 9e5b958e DEBUG Could not delete from Notificationsno such table: Notifications
2015/09/06 18:59:54 e170c668 9e5b958e DEBUG Could not insert into Notifications-Tableno such table: Notifications
2015/09/06 18:59:54 e170c668 9e5b958e INFO Starting instance ts3server://localhost?port=9987&nickname=Stimmungsmacher&password=&cid=27&channelpassword=
2015-09-06 18:59:54.914873|INFO | | | TeamSpeak 3 Client 3.0.16 (2014-08-04 13:42:43)
2015-09-06 18:59:54.915614|INFO | | | SystemInformation: Linux 3.2.0-4-amd64 #1 SMP Debian 3.2.68-1+deb7u1 x86_64 Binary: 64bit
2015-09-06 18:59:54.915940|INFO | | | Using hardware aes
2015-09-06 18:59:54.927886|DEBUG |PulseAudio | | connected to pulse audio server
2015-09-06 18:59:54.940853|INFO | | | Loading plugin: libappscanner_plugin
2015-09-06 18:59:54.940923|INFO | | | Loading plugin: libclientquery_plugin
2015-09-06 18:59:54.940946|INFO | | | Loading plugin: liblua_plugin
2015-09-06 18:59:54.940967|INFO | | | Loading plugin: libsoundbot_plugin
2015-09-06 18:59:54.940986|INFO | | | Loading plugin: libtest_plugin
2015-09-06 18:59:54.942226|INFO |Query | | listening on 127.0.0.1:25639
2015-09-06 18:59:55.106710|INFO |ClientUI | | Failed to init text to speech engine
2015-09-06 18:59:55.106804|INFO |ClientUI | | Qt version: 5.2.1
2015-09-06 18:59:55.106831|INFO |ClientUI | | Using configuration location: /opt/ts3soundboard/data/ts3/e170c668-7a04-4eff-b683-acaa67de6f64/9e5b958e-b382-4187-893b-f6c2acc457e5/settings.db
2015-09-06 18:59:55.405098|INFO |ClientUI | | ts3server: localhost?port=9987&nickname=Stimmungsmacher&password=&cid=27&channelpassword=
2015-09-06 18:59:55.405680|INFO |ClientUI | 1| Connect to server: localhost
2015-09-06 18:59:55.409194|INFO |ClientUI | 1| Trying to resolve localhost
2015-09-06 18:59:55.413230|INFO |TSDNS | | DNS resolve successful, "localhost"=127.0.0.1
2015-09-06 18:59:55.415271|INFO |TSDNS | | SRV DNS resolve unsuccessful for "_ts3._udp.localhost"
2015-09-06 18:59:55.417593|INFO |ClientUI | 1| Lookup finished: 127.0.0.1 9987 localhost 0 0
2015-09-06 18:59:55.417674|INFO |ClientUI | 1| Resolve successful: 127.0.0.1:9987
2015-09-06 18:59:55.418001|INFO |ClientUI | 1| Blacklist check ok
2015-09-06 18:59:55.418141|INFO |ClientUI | 1| Initiating connection: 127.0.0.1:9987 localhost
2015-09-06 18:59:55.571833|INFO |PreProSpeex | 1| Speex version: 1.2rc1
2015-09-06 18:59:55.707544|INFO |ClientUI | 1| Connect status: Connecting
2015-09-06 18:59:55.709580|INFO |ClientUI | | Last update check was: Sun Jan 1 00:00:01 2017
2015-09-06 18:59:55.710649|DEVELOP |PktHandler | | Puzzle solve time: 5
2015-09-06 18:59:55.713373|INFO |EncodeCelt | 1| CELT bitstream version: 0x80000010
2015-09-06 18:59:55.716286|INFO |ClientUI | 1| Connect status: Connected
2015-09-06 18:59:55.723572|INFO |ClientUI | 1| Connect status: Establishing connection
2015-09-06 18:59:55.730728|INFO |ClientUI | 1| Connect status: Connection established
2015-09-06 18:59:55.732072|INFO |PermManager | | Loading permissions from cache
2015-09-06 19:00:00.520134|INFO |ClientUI | | Blacklist check timeout
2015/09/06 19:00:06 e170c668 9e5b958e INFO PLAY [admin] 7246c23b-0825-4bf2-8e7a-ea09dcbd3123 OK
2015/09/06 19:00:06 e170c668 9e5b958e DEBUG New channel
2015/09/06 19:00:08 e170c668 9e5b958e WARN Could not send chat command
2015/09/06 19:00:13 e170c668 9e5b958e DEBUG Storing configuration.
2015/09/06 19:00:28 e170c668 9e5b958e WARN Could not send config
2015/09/06 19:00:48 e170c668 9e5b958e INFO KILL [admin] FAILED
Liebe Grüße.
