bot running, no music in ts
MegaClan
the bot is started
the Web Interface is connected and everything set up, at least let you ask.
but when I put some music to play in ts3 not hear the sound, and the bot is "continuous sound" on.
Bot has Server Admin
I have Server Admin
But the controls do not work in chat, I write and do nothing.
MegaClan
Image folder
config.ini
TS3Path = "C:\\Program Files\\TeamSpeak 3 Client\\ts3client_win64.exe"
YoutubeDLPath = "C:\\ts3\\youtube-dl.exe"
MTU = 1500
SampleInterval = 100
LicenseKey = "dfxtYjgHdYVNJwYH4JcFAlHgdcxoWAdBHEhmGqI9xwY="
EnableAloneMode = false
Please check C:\Program Files\TeamSpeak 3 Client\plugins is there a ts3_soundboardbot.dll or similar name? I don't know the exact name under windows currently.
Why did you change the path to C:\Program Files\... in the first place? The installer usually copies everything the bot needs to the installation folder. And why is there a serverTS3 in that path as well?
Please remove everything and install again _without_ changing the default config file.
Also, that soundboard.dll is my soundboard plugin - which has got nothing to do with the bot itself. :)
MegaClan
serverTS3 is my local host for test the bot.
my ts install for default in C:\Program Files\TeamSpeak 3 Client\
why?
and soundboard.dl file is @Xuxe
I re-install all
Sorry my bad english, I'm from brazil =\
MegaClan
I'm opening sinusbot-win-0.9.8.6.exe
Installing... (C:\SinusBot default)
I input youtube-dl.exe and youtube-dl.exe.sig in folder SinusBot.
settings in "config.ini"
I'm opening the '' ts 3 bot.exe for the first time.
Image:
I change only
YoutubeDLPath = "C:\\SinusBot\\youtube-dl.exe
and
TS3Path = ""C:\\Program Files\\TeamSpeak 3 Client\\ts3client_win64.exe"
I'm opening the ts3bot.exe for the tow time.
He opened all the windows left when I opened the bot
and so? the commands in the chat does not work
Thank you for reply
Do NOT change that. The installer copies the bot over to your bot installation directory AND installs a plugin that is _required_ for the bot to work.
Could you please explain how you solved it? Maybe someone else runs into the same problem as well.
MegaClan
just do everything I did above, and do not change the default path of the TeamSpeak 3 client
for some reason this BOT has a specific type of sound driver, then leave the standard TS3 Client directory in config.ini
