Solved Bot spielt nur auf bestimmten Teamspeak Musik
Rich (BB code):
2019-03-31T23:10:41+02:00 Storing configuration.
2019-03-31T23:10:23+02:00 Done playing
2019-03-31T23:10:23+02:00 Channels now zero
2019-03-31T23:10:23+02:00 Deleting channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID cb6ea7e1-5f8d-4e2d-81b8-f5bd72e1680e (cc 1)
2019-03-31T23:10:23+02:00 Removing closed channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID cb6ea7e1-5f8d-4e2d-81b8-f5bd72e1680e
2019-03-31T23:10:23+02:00 Sending stop to b0d54256-719f-460e-beb1-dfbceda5e685 () ID cb6ea7e1-5f8d-4e2d-81b8-f5bd72e1680e #1
2019-03-31T23:10:23+02:00 STOP [admin] OK
2019-03-31T23:10:23+02:00 Stopping
2019-03-31T23:10:22+02:00 PLAY [admin] b0d54256-719f-460e-beb1-dfbceda5e685 OK
2019-03-31T23:10:22+02:00 New channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID cb6ea7e1-5f8d-4e2d-81b8-f5bd72e1680e (cc 0)
2019-03-31T23:09:41+02:00 Done playing
2019-03-31T23:09:41+02:00 Channels now zero
2019-03-31T23:09:41+02:00 Deleting channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID fe9f01c1-1917-4566-98e0-6e7350484bce (cc 1)
2019-03-31T23:09:41+02:00 Removing closed channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID fe9f01c1-1917-4566-98e0-6e7350484bce
2019-03-31T23:09:41+02:00 Storing configuration.
2019-03-31T23:09:40+02:00 Sending stop to b0d54256-719f-460e-beb1-dfbceda5e685 () ID fe9f01c1-1917-4566-98e0-6e7350484bce #1
2019-03-31T23:09:40+02:00 STOP [admin] OK
2019-03-31T23:09:40+02:00 Stopping
2019-03-31T23:09:39+02:00 Deleting channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID af38b425-c27b-4f80-be9e-83ef9c0e5907 (cc 2)
2019-03-31T23:09:39+02:00 Removing closed channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID af38b425-c27b-4f80-be9e-83ef9c0e5907
2019-03-31T23:09:39+02:00 Removing duplicate channel for alias b0d54256-719f-460e-beb1-dfbceda5e685 () ID af38b425-c27b-4f80-be9e-83ef9c0e5907
2019-03-31T23:09:39+02:00 New channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID fe9f01c1-1917-4566-98e0-6e7350484bce (cc 1)
2019-03-31T23:09:39+02:00 PLAY [admin] b0d54256-719f-460e-beb1-dfbceda5e685 OK
2019-03-31T23:09:39+02:00 Sending stop to b0d54256-719f-460e-beb1-dfbceda5e685 () ID af38b425-c27b-4f80-be9e-83ef9c0e5907 #1
2019-03-31T23:09:39+02:00 STOP [admin] OK
2019-03-31T23:09:39+02:00 Stopping
2019-03-31T23:09:33+02:00 New channel b0d54256-719f-460e-beb1-dfbceda5e685 () ID af38b425-c27b-4f80-be9e-83ef9c0e5907 (cc 0)
2019-03-31T23:09:33+02:00 new track info: Embassy One - Yves LaRock - Rise Up (456d6261737379204f6e65202d2059766573204c61526f636b202d2052697365205570)
2019-03-31T23:09:33+02:00 PLAY [admin] b0d54256-719f-460e-beb1-dfbceda5e685 OK
2019-03-31T23:09:12+02:00 TS |INFO |Update | |Check license: version=4, min_version=4, my_license_version=4, my_license_min_version=1
2019-03-31T23:09:12+02:00 2568/insufficient client permissions/i_channel_needed_description_view_power
2019-03-31T23:09:12+02:00 TS |INFO |Update | |Checking for updates...
2019-03-31T23:09:12+02:00 TS |INFO |ClientUI | |Checking for update
2019-03-31T23:09:12+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
Geh mal bitte im Webinterface auf:
Settings -> Info -> About...
und sagmal welche Version dein Sinusbot hat.
Habe irgendwie die Vermutung, dass das einer der Bugs der 0.14 ist, und du die noch nutzt.
Weil der Bot empfängt deine Commands, und setzt sie auch um. Es kommt aber nur kein Sound im Teamspeak?
Das Lied, welches abgespielt werden soll, ist einfach testweise eine MP3 hochgeladen?
service sinusbot stop
su sinusbot
cd /opt/sinusbot
curl -O https://www.sinusbot.com/pre/sinusbot-1.0.0-alpha.6-a47ac17.tar.bz2
tar -xjvf sinusbot-1.0.0-alpha.6-a47ac17.tar.bz2
cp plugin/libsoundbot_plugin.so TeamSpeak3-Client-linux_amd64/plugins/
service sinusbot start
und fertig
schreib mal
wget https://www.sinusbot.com/pre/sinusbot-1.0.0-alpha.6-a47ac17.tar.bz2
ich bin müde sorry
du hast installer script benutzt ne?
cp plugin/libsoundbot_plugin.so teamspeak3-client/plugins
Noch ein Tipp: Wenn du dich langfristig mit Sinusbot usw. auseinandersetzen willlst, solltest du anfangen, die zumindest ein rudimentäres Grundwissen bzgl. Linux zuzulegen. Das klappt bereits mit 10 Minuten googlen. (Befehle: cd, ls, usw....) Dann verstehst du auch, was die Zeile macht, die du im Moment immer nur stumpfsinnig kopierst und Enter drückst.
Und du kannst mit der Fehlermeldung auch sehen, was da schiefläuft. In dem Fall existiert der Zielordner nicht, somit könntest du selbst nachschauen, wie der Ordner in deinem Fall heißt, und das Command entsprechend anpassen.
Ich weiß, es ist bequemer, hier alles mundgerecht runterzuschlucken, aber irgendwann muss man auch mal Messer und Gabel selbst in die Hand nehmen.
Wenn du nachvollziehen kannst, welche Befehle dir @Himsel genannt hat, und was diese getan haben auf deinem System, ist das schon ein super Anfang! :)
Werde ich auf jedenfall machen. ^^
