Cant edit Settings
akira_txt
Im unable to modify the instance settings, alrrady tried doing it in the site and its not letting me edit them, i cant even turn off the instance.
2015/10/25 03:03:01 cdc7591f cdefd7ab WARN Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2015/10/25 03:03:01 cdc7591f cdefd7ab INFO KILL [admin] FAILED
I have allow all in my Firewall.
I put the following permissions:
chown -R sinusbot:sinusbot /home/sinusbot/data
chown sinusbot:sinusbot /home/sinusbot/config.ini
Thanks in advance
Beta 0.9.9 f25ac00
Linux Ubuntu 14.04
VPS 2gb RAM OpenVZ
Chrome
config.ini:
ListenHost = "x.x.x.x"
LogLevel = 3
EnableProfiler = true
MTU = 1500
LicenseKey = "pfC8IBSKodD+JJRkpXZhtlgpcXyeDCYkTxubi8l87xg="
DisableLocalXServer = false
DebugLocalXServer = false
Console:
sinusbot@mail:~$ ./sinusbot
Version: 0.9.9-f25ac00
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2015/10/25 04:09:14 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
Generating new bot instance with account 'admin' and password 'foobar'
2015/10/25 04:09:14 X [MAIN] Starting up fake x-server...
2015/10/25 04:09:14 Updating database to v1... 0
2015/10/25 04:09:14 Updating database to v2... 1
2015/10/25 04:09:14 Updating database to v3... 2
2015/10/25 04:09:14 3066e3ee INFO Loading instances
2015/10/25 04:09:14 3066e3ee INFO Creating default instance
2015/10/25 04:09:15 3066e3ee 887af29d INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/10/25 04:09:15 3066e3ee INFO Promoting instance to main instance
2015/10/25 04:09:15 3066e3ee INFO Adding new useradmin
2015/10/25 04:09:15 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/10/25 04:09:15 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/10/25 04:09:15 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://x.x.x.x:8087
2015/10/25 04:09:15 [GENERAL/RADIO ] INFO Could not find RadioStation-Data, updating...
2015/10/25 04:09:15 X [MAIN] New connection
Crashdump ENABLED, directory is: /home/sinusbot/data/ts3/3066e3ee-4c84-4f89-b167-50044d0953e5/887af29d-ebde-47be-b386-dfdd2336f096/crashdumps
DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/3066e3ee-4c84-4f89-b167-50044d0953e5/887af29d-ebde-47be-b386-dfdd2336f096/crashdumps
2015-10-25 10:09:15.340778|INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015-10-25 10:09:15.340972|INFO | | |SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
2015-10-25 10:09:15.341146|INFO | | |Using hardware aes
2015/10/25 04:09:15 X [MAIN] Disconnected: 1
2015/10/25 04:09:15 X [MAIN] Disconnected: 2
tracks 11263
2015/10/25 04:09:16 [GENERAL/RADIO ] INFO RadioStation data loaded
2015/10/25 04:09:17 [GENERAL/RADIO ] INFO Imported radio stations
2015/10/25 04:09:19 3066e3ee 887af29d WARN Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2015/10/25 04:09:45 3066e3ee INFO LOGIN [admin] OK
Do you have an XServer installed that is running?
Could you please set
in your config.ini and paste your log?
akira_txt
I have vncserver installed, but this is not running.
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2015/10/25 05:03:14 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2015/10/25 05:03:14 c69a0b3d          INFO   Initializing bot://c69a0b3d-1476-442e-8b47-6c0abdf7e2e1
2015/10/25 05:03:14 X [MAIN] Starting up fake x-server...
2015/10/25 05:03:14 c69a0b3d          INFO   Loading instances
2015/10/25 05:03:14 c69a0b3d          INFO   Loading instance://7e577119-7b74-4f95-adf8-5675af24378a
2015/10/25 05:03:14 c69a0b3d 7e577119 INFO   Initialization complete
2015/10/25 05:03:14 c69a0b3d 7e577119 INFO   Auto-Starting c69a0b3d-1476-442e-8b47-6c0abdf7e2e1/7e577119-7b74-4f95-adf8-5675af24378a in 500 ms...
2015/10/25 05:03:14 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/10/25 05:03:14 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/10/25 05:03:14 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://xxxxxxx:8087
2015/10/25 05:03:14 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2015/10/25 05:03:15 c69a0b3d 7e577119 WARN   Could not delete from Profilesno such table: Profiles
2015/10/25 05:03:15 c69a0b3d 7e577119 WARN   Could not insert into Profiles-Tableno such table: Profiles
2015/10/25 05:03:15 c69a0b3d 7e577119 DEBUG  Could not delete from Notificationsno such table: Notifications
2015/10/25 05:03:15 c69a0b3d 7e577119 DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2015/10/25 05:03:15 c69a0b3d 7e577119 DEBUG  Could not delete from Newsno such table: News
2015/10/25 05:03:15 c69a0b3d 7e577119 DEBUG  Could not insert into News-Tableno such table: News
2015/10/25 05:03:15 c69a0b3d 7e577119 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/10/25 05:03:15 X [MAIN] New connection
2015/10/25 05:03:15 [GENERAL/RADIO  ] INFO   Imported radio stations
2015/10/25 05:03:15 X [MAIN] Disconnected:  1
2015/10/25 05:03:15 X [MAIN] Disconnected:  2
2015/10/25 05:03:43 c69a0b3d 7e577119 DEBUG  Storing configuration.
2015/10/25 05:03:44 [GENERAL        ] Shutting down... Hold on...
2015/10/25 05:03:44 X [MAIN] Disconnected:  0
2015/10/25 05:03:44 c69a0b3d 7e577119 INFO   TSClient quit.
2015/10/25 05:03:44 c69a0b3d 7e577119 DEBUG  Stopping TS
2015/10/25 05:03:44 c69a0b3d 7e577119 WARN   Could not request shutdown. Please make sure that the loopback interface is not firewalled.
Sorry, I meant
DebugLocalXServer = true
Hmm... something's new in your environment that the bot can't handle in the current version. Could you please try again with this version?
If it still doesn't work, please send me that log again.
Thanks for your patience :/
akira_txt
Same problem, can't edit... this is because Teamspeak Client is running maybe in First Run.
Then, why Teamspeak client is executed in the First Run?
First run:
Version: 0.9.9-794bf88
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2015/10/25 05:39:10 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2015/10/25 05:39:10 X [MAIN] Starting up fake x-server...
2015/10/25 05:39:10 Updating database to v1... 0
2015/10/25 05:39:10 Updating database to v2... 1
2015/10/25 05:39:10 Updating database to v3... 2
2015/10/25 05:39:10 eb15c341          INFO   Loading instances
2015/10/25 05:39:10 eb15c341          INFO   Creating default instance
2015/10/25 05:39:10 eb15c341 2481b0e6 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/10/25 05:39:10 eb15c341          INFO   Promoting instance to main instance
2015/10/25 05:39:10 eb15c341          INFO   Adding new useradmin
2015/10/25 05:39:10 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/10/25 05:39:10 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/10/25 05:39:10 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://xxxxxxxxx:8087
2015/10/25 05:39:10 X [MAIN] New connection
2015/10/25 05:39:10 [GENERAL/RADIO  ] INFO   Could not find RadioStation-Data, updating...
Crashdump ENABLED,  directory is: /home/sinusbot/data/ts3/eb15c341-074f-4914-8e0b-224c234efd2c/2481b0e6-8c36-4e29-af48-6d1b9d16de18/crashdumps
DUMP defined! Dumpdir is: /home/sinusbot/data/ts3/eb15c341-074f-4914-8e0b-224c234efd2c/2481b0e6-8c36-4e29-af48-6d1b9d16de18/crashdumps
2015-10-25 11:39:10.783627|INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015-10-25 11:39:10.783880|INFO    |              |   |SystemInformation: Linux 2.6.32-042stab108.5 #1 SMP Wed Jun 17 20:20:17 MSK 2015 x86_64 Binary: 64bit
2015-10-25 11:39:10.784004|INFO    |              |   |Using hardware aes
2015/10/25 05:39:10 X [MAIN] Disconnected:  1
2015/10/25 05:39:11 X [MAIN] New connection
2015/10/25 05:39:11 X [MAIN] Disconnected:  2
tracks 11035
2015/10/25 05:39:11 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2015/10/25 05:39:12 [GENERAL/RADIO  ] INFO   Imported radio stations
2015/10/25 05:39:15 eb15c341 2481b0e6 WARN   Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2015/10/25 05:39:46 eb15c341          INFO   LOGIN [admin] OK
2015/10/25 05:39:49 eb15c341 2481b0e6 WARN   Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2015/10/25 05:39:49 eb15c341 2481b0e6 INFO   KILL [admin] FAILED
Logs with "DebugLocalXServer = true": http://pastebin.com/nNEt874G
akira_txt
@flyth works!
But now I have this problem:
2015/10/25 15:13:17 fa8bd2d7 9c151450 DEBUG  TS/ERR 524 e'client is flooding' x'' r'PR:{ebd06f1d-d7d8-44e0-9ebd-da71f35b4b7e}:3/PLIS'
2015/10/25 15:13:17 fa8bd2d7 9c151450 DEBUG  TS/ERR 524 e'client is flooding' x'' r'PR:{ebd06f1d-d7d8-44e0-9ebd-da71f35b4b7e}:4/INIT'
My bot is in whitelist, works fine can connect to my server, but this error SPAM in console. Sorry for my bad english.
Great to hear that!
With whitelist you mean the serverquery? Because that won't work. You need to give it a permission for that - I guess it's b_client_ignore_antiflood.
akira_txt
Oh thanks, now I have this problem:
2015/10/25 15:42:58 fa8bd2d7 9c151450 DEBUG  TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{c2ef678c-4c5e-4541-b561-33de9509da27}:15/GCLL'
That's not a problem at all - you're just seeing it, because you still have the debug messages enabled. You should set
LogLevel = 3
again.
