Solved Client not starting/connecting
Mickimoo2
System Version:
Ubuntu 14.04
Sinus Bot Version:
9.8 & 9.9.3
Hardware Specs:
Xeon E3 1245v2, 32GB DDR3, 250Mb/s link, 240GB SSD
Browser:
Chrome (Version 46.0.2490.71 (64-bit))
Config.ini:
http://pastie.org/private/wfkbmlxcflg1dsajefpw
Log Level 10 Output:
http://pastie.org/private/ugclfgzx2gjdovdfnxrlyg
Basically it gives me an orange pop up in 9.9.3 saying that it might be a wrong name, address or security level.
The problem originated in 9.8 so I tried partially reinstalling, didn't work. Updated to 9.9.3 and it still continued.
Many thanks for your help in advance :)
EDIT:
It is not banned on the server (I tried with the machine's client key and an exported copy of mine)
The TS3 server version is 3.0.11.4 (Hosted by Enjin)
The TS3 client seems to be the problem but it was all working then all of a sudden it left the channel and can't come back again.
CrAazZyMaN21
System Version:
Ubuntu 14.04
Sinus Bot Version:
9.8 & 9.9.3
Hardware Specs:
Browser:
Config.ini:
Is your bot banned that happend to me last time :D
I could also be that your TS Cleint is 3.0.16 and not 3.0.18.1 and the lower Version is banned from the Teamspeak you want to connect.
Mickimoo2
That shouldn't be a problem since the server is running 3.0.11.4 (Hosted by enjin) and I have checked that it isn't banned since I also had made a copy of my own client key and tried that.
Bot Crashes On Start
I see here no crashdump?
Is it a crash or is the Client not starting/connecting?
Mickimoo2
Sorry I meant the TS3 client seems to be quitting(in my words crashing since it throws errors before doing so) when I went through the level 10 log.
Sorry for the late reply.
That Version missmatch can be the Problem: https://forum.sinusbot.com/threads/security-announcement-by-teamspeak.571/#post-3100
Stopp your Instance and Download your TS3-Client again (http://www.teamspeak.com/downloads) with the latest Version and copy it over the old Client.
Now try again.
Mickimoo2
Thank you, this has fixed my issue :) ( Might I suggest updating your ubuntu / debian installation guide )
You may lock this thread now, thank you for your assistance.
