Solved Cloudflare sinusbot port unlock
frishu
Hello, I've got a question about webinterface port compatibility with cloudflare.
I am using CF to mask my vps IP. Becouse of that I can't use the :8087 port. When I want to use my normal vps IP with port it's working normally. I would like to do it with srv, can someone tell me which service name should I use and which ports should be unlocked?
Thanks a lot for your help.
Greetings, frishu.
Greetings, frishu.
You could set up a reverse proxy, more information about that can be found in the wiki.
Patschi
Or change the port of the Sinusbot webinterface to any of Cloudflare supported ports.
