Bug Could not load tracks
Skylamon
After unexpected power outage, the bot no longer finds any tracks, but keeps playing music in the teamspeak.
!next and !playlist commands all work and music plays, but webinterface is just stuck.
Info from bot log :
2016-06-15T11:48:37+03:00 Added EVListener
2016-06-15T11:48:27+03:00 Loading instance://d2c4cdbb-e461-40fb-9912-21c087fe93b7
2016-06-15T11:48:27+03:00 Loading instance://78f2b191-a8d6-40c8-9632-552c3a3ae10a
2016-06-15T11:48:27+03:00 Loading instances
2016-06-15T11:48:27+03:00 Could not get tracks
Info from instance log :
2016-06-15T11:48:27+03:00 Initialization complete
From diagnostics script
 - Operating System: Ubuntu 14.04.4 LTS
 - Kernel: Linux 3.19.0-61-generic x86_64
 - Load Average: 0.76 0.61 0.49
 - Uptime: 0 days, 0 hours, 16 minutes, 12 seconds
 - OS APT Last Update: 15.06.2016 11:35:51 EEST +03:00:00
  Architecture:  x86_64
  CPU(s):  4
  Thread(s) per core:  1
  Core(s) per socket:  4
  Socket(s):  1
  CPU MHz:  2812.732
  Hypervisor vendor:  KVM
  Virtualization type:  full
 - RAM: 899.43 MB/992.82 MB in use (90%)
 - DISK: 6.13 GB/66.59 GB in use (9%)
  > libglib: 2.40.2-0ubuntu1
 - Status: running (PIDs: 4576 4575, User: sky)
 - Webinterface: port locally not reachable (Port: 8093)
 - Binary: /opt/ts3soundboard/sinusbot (Hash: 8b94daaaf3ffd829669e70a3c6a5843d)
 - Version: 0.9.12-58b509d
  - Bot Plugin: 2c207af25e3000543d85b5f4275ef053
  - TS3 Client: 2c207af25e3000543d85b5f4275ef053
  - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.03.18)
 - Report date: 15.06.2016 11:51:28 EEST +03:00:00 (timezone: Europe/Tallinn)
 - youtube-dl Version: 2016.03.18
 - DiagScript version: 0.4.5
Anyway to fix this ?
