Could not request shutdown. Please make sure that the loopback interface is not firewalled.
LukBoy99
Hello, I have 7 instances, one of them works perfectly the rest don't work even tho all are licensed and same and first time on server ( did clean reinstall of sinusbot cause !sub was being bugged )
example instance log of one unable to connect:
2016-07-15T17:41:03+03:00 Storing configuration.
2016-07-15T17:40:58+03:00 Ping failed.
2016-07-15T17:40:48+03:00 Starting instance ts3server://51.254.161.138?port=9987&nickname=TOP%20HITS%20BOT&password=&channel=&channelpassword=
2016-07-15T17:40:48+03:00 Could not insert into Notifications-Tableno such table: Notifications
2016-07-15T17:40:48+03:00 Could not delete from Notificationsno such table: Notifications
2016-07-15T17:40:34+03:00 Initialization complete
Sometime they can connect but they have disabled microphone (1/10 times)
This is instance log of when they connect with disabled sometimes:
http://pastebin.com/he2QPdEL
This is bot log
http://pastebin.com/sT6TvmHm
This is my config
http://pastebin.com/QUXuRxbh
I think i put everything, please help xd
LukBoy99
100% clean reinstall again, it worked without license so i closed, added private.dat and added license and changed licensekey in config and then i get this mess when starting (didnt use start script this time)
http://pastebin.com/N9Xju0MX
Xuxe is magic ;) - You may used the latest beta with xinit? ^^
LukBoy99
It's quite old, friend gave it to me when I first downloaded sinusbot but works fine
#! /bin/bash
### BEGIN INIT INFO
# Provides: ts3bot
# Required-Start: $local_fs $network
# Required-Stop: $local_fs $network
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Description: Sinusbot
### END INIT INFO
# Usage: ./launch.sh {start|stop|status|restart|console|update|backup} #
# - start: start the bot #
# - stop: stop the bot #
# - status: display the status of the bot (down or up) #
# - restart: restart the bot #
# - console: display the bot console #
# - update: runs the bot updater (with start & stop)
# - backup: archives your bot root directory
# To exit the console without stopping the server, press CTRL + A then D. #
SCREEN_NAME="sinusbot"
USER="sinusbot"
DIR_ROOT="/home/sinusbot"
DIR_BACKUP="/home/backup/sinusbot"
BOT_RUNCMD="./sinusbot"
BOT_UPDATE_ARG=" -update"
# No edits necessary beyond this line
PATH=/bin:/usr/bin:/sbin:/usr/sbin
if [ ! -x `which screen` ]; then echo "ERROR: You need screen for this script (try apt-get install screen)"; exit 1; fi
if [ ! -x `which tar` ]; then echo "WARNING: You need tar for the Backup Function (try apt-get install tar)";  fi
function start {
    if [ ! -d $DIR_ROOT ]; then echo "ERROR: $DIR_ROOT is not a directory"; exit 1; fi
    if status; then echo "$SCREEN_NAME is already running"; exit 1; fi
    # Start bot
    if [ `whoami` = root ]
    then
        su - $USER -c "cd $DIR_ROOT ; screen -AmdS $SCREEN_NAME $BOT_RUNCMD"
    else
        cd $DIR_ROOT
    fi
function backup {
    DATE=$(date +%Y-%m-%d)
    then
        su - $USER -c "cd $DIR_ROOT ; tar -cjpf $DIR_BACKUP/sinusbot-$DATE.tar.bz2 $DIR_ROOT"
    else
        cd $DIR_ROOT
    fi
function update {
    then
        su - $USER -c "cd $DIR_ROOT ; $BOT_RUNCMD$BOT_UPDATE_ARG"
    else
        cd $DIR_ROOT
    fi
function stop {
    if ! status; then echo "$SCREEN_NAME could not be found. Probably not running."; exit 1; fi
    then
        su - $USER -c "screen -S $SCREEN_NAME -X stuff '\003'"
    else
    fi
function status {
    then
        su - $USER -c "screen -ls" | grep [.]$SCREEN_NAME[[:space:]] > /dev/null
    else
        screen -ls | grep [.]$SCREEN_NAME[[:space:]] > /dev/null
    fi
function console {
    then
        su - $USER -c "screen -x $SCREEN_NAME"
    else
    fi
function usage {
    echo "Usage: $0 {start|stop|status|restart|console}"
    echo "On console, press CTRL+A then D to stop the screen without stopping the server."
case "$1" in
start)
    echo "Using following data:"
    echo "USER: $USER"
    echo "DIR ROOT: $DIR_ROOT"
    echo "BOT RUN CMD: $BOT_RUNCMD"
    echo ""
    sleep 2
    echo "Starting $SCREEN_NAME..."
    start
    sleep 2
    echo "$SCREEN_NAME started successfully"
stop)
    echo "Stopping $SCREEN_NAME..."
    stop
    sleep 2
    echo "$SCREEN_NAME stopped successfully"
restart)
    echo "Restarting $SCREEN_NAME..."
    status && stop
    sleep 5
    start
    sleep 2
    echo "$SCREEN_NAME restarted successfully"
status)
    if status
    then echo "$SCREEN_NAME is UP"
    else echo "$SCREEN_NAME is DOWN"
    fi
console)
    echo "Open console on $SCREEN_NAME..."
    console
update)
    if status
    then stop && sleep 5 && update
    else update
    fi
backup)
    if [ -d "$DIR_BACKUP" ]
    then
            if status
            then stop && sleep 5 && backup
            else backup
            fi
    else echo "BACKUP DIRECTORY NOT EXISTS. EXIT!"; exit 1;
    fi
    usage
    exit 1
esac
exit 0
