Used Version: sinusbot-win-0.9.8.6
Operating System: Windows Server 2012 R2 Standard
Hardware Specs: Hyper-V Virtual Machine, allocated resources: 4GB RAM @ 1333MHz, 4 cores @ 2.40GHz (Intel Xeon E5620)
Used Browser: Google Chrome, no plugins
Config.ini:
UploadLimit = 2500000000
InstanceActionLimit = 25
MTU = 1500
EnableWebStream = true
LicenseKey = "zpVUwIDL0Tyvny6i4X6lQrHeSB0WA3pmnKWnjHRzcyw="
EnableAloneMode = false
Issue #1: I have a large library (about 12,000 songs, 50GB). By the time I scroll to about 2-3 thousands down the folder in browser, it just crashes. I notice a high spike in disk usage (I'm assuming because of all the cached icon images loading at 10 MB/s), but no increase in CPU or memory usage. Generally not an issue, but the bulk select only seems to select items loaded on the screen.
The computer I'm running the browser on has 32GB ram, tons of free memory (and
Issue #2: I'm trying to add the folder to a playlist, but it only adds the first 1001 songs. It doesn't seem to be a limit with playlists because I can add more songs after that, but there's no easy way for me to add them all it seems (I can't just scroll down, select the next 1000 and move on, because issue #1 crashes during those attempts)
Overview: I'm not so worries about loading all the songs in the folder, because I know it a lot of content and will just slow things down, and isn't really needed once I narrow down with search, BUT, I need some way to add this entire huge folder to a playlist.
Thank you
Config.ini:
MTU = 1500
Thank you
