EN |DE - PHP Sorting output
Kamikaze
Hey Guys!
I need help by sorting the array of playlists. Here my sorting function (working)
PHP:
<?php
require("../login.php");
$playlist = $sinusbot->getPlaylists();
$playname = $playlist;
function aasort (&$array, $key) {
    $sorter=array();
    $ret=array();
    reset($array);
    foreach ($array as $ii => $va) {
        $sorter[$ii]=$va[$key];
    asort($sorter);
    foreach ($sorter as $ii => $va) {
        $ret[$ii]=$array[$ii];
    $array=$ret;
aasort($playname,"name");
echo "<pre>";
print_r($playname);
echo "</pre>";
So when I try to use it on my script to display playlist include tracks it don't want to work :(
The Script:
PHP:
<?php
for ($a = 0; $a < count($playlist); $a++) {
    $playuuid = $playlist[$a]["uuid"];
// Sort Array
    $sorter=array();
    $ret=array();
    reset($array);
    asort($sorter);
    $array=$ret;
$divCounter = 1;
    $playname = $playlist[$a]["name"];
    $playlistTracks = $sinusbot->getPlaylistTracks($playuuid);
    $playlistTracks = $playlistTracks["entries"];
    If($a >= 1) {
        echo "<hr/>";
    echo "
            <div class=header>
            <a class=collapsing href=# onclick=toggle_visibility('plisttracks$divCounter');>
                <div class=collapse>&#10084;</div>
                <h2>" . $playname . "</h2>
            </a>
            </div>";
    echo "<div id=plisttracks$divCounter class=plisttracks style=display:none;>";
    $divCounter++;
    $trackCounter = 1;
    for ($i = 0; $i < count($playlistTracks); $i++) {
        echo "<div id=filenr>" . $trackCounter . "</div>" . "<div id=filename>" . $playlistTracks[$i]["title"] . '</div>';
        $trackCounter++;
        //print_r($playlistTracks);
    echo "</div>";
The ouput is still random so no sorting.
Tried to put
PHP:
on different places but still don't work.
Anyone could help me?
Kamikaze
Solved it.
Didn't thought that the keys of the sorted array are still the same like
Array
    [9] => AAA
    [10] => BBB
    [6] => CCC
Changed it with "$playlist = array_values($playlist);"
- Can be closed / Kann geschlossen werden -
