Discord: Sinusbot doesn't play sound after the bot was moved to a channel
Dreandor
The Discordbot joins automaticly a channel. Then if I move him to my channel the bot won't play any sound.
 - Operating System: Debian GNU/Linux 11 (bullseye)
 - Kernel: Linux 5.10.0-26-cloud-amd64 x86_64
 - Load Average: 0.19 0.12 0.10
 - Uptime: 0 days, 8 hours, 2 minutes, 56 seconds
 - OS APT Last Update: 25.12.2023 03:00:05 CET +01:00:00
 - Shell Locale: C.UTF-8
    Architecture:                       x86_64
    CPU(s):                             6
    Thread(s) per core:                 2
    Core(s) per socket:                 1
    Socket(s):                          3
    Model name:                         AMD EPYC-Milan Processor
    CPU MHz:                            1999.999
    Virtualization:                     AMD-V
    Hypervisor vendor:                  Microsoft
    Virtualization type:                full
 - RAM: 6.87 GB/15.60 GB in use (44%)
 - DISK: 243.65 GB/491.98 GB in use (49%)
   - libglib: 2.66.8-12.66.8-1
 - Status: running (PIDs: 31201 31200, User: sinusbot)
 - Binary Info: MD5 Hash: 72d16bcac5d8e0df94ba49def894e52f, Perms: 755, User: sinusbot
 - Version:
 - TS3 Plugin: unknown (TS3client not found)
   - Bot Plugin: unknown
   - TS3 Client: unknown
   - TS3Path =  (TS3client-binary does not exist!)
   - YoutubeDLPath = /usr/local/bin/yt-dlp (does exist, version: 2023.11.16)
 - Installed scripts: advertising.js; alonemode.js; bookmark.js; come.js; command.js; followme.js; norecording.js; rememberChannel.js; sinusbot-commands.js; welcome.js
   - TS3Client/libqxcb-glx-integration.so:
    linux-vdso.so.1 (0x00007ffc01531000)
    libswresample.so.4 => /opt/sinusbot/libswresample.so.4 (0x00007f7623f0e000)
    libavfilter.so.8 => /opt/sinusbot/libavfilter.so.8 (0x00007f7623b0c000)
    libavformat.so.59 => /opt/sinusbot/libavformat.so.59 (0x00007f7623888000)
    libavcodec.so.59 => /opt/sinusbot/libavcodec.so.59 (0x00007f76225a8000)
    libavutil.so.57 => /opt/sinusbot/libavutil.so.57 (0x00007f76223cd000)
    libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f76223a1000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f7622399000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f7622377000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f76221aa000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f7622066000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f762204c000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f7621e78000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f7623f32000)
    libswscale.so.6 => /opt/sinusbot/libswscale.so.6 (0x00007f7621dcb000)
 - DNS resolution check: SUCCESS [www.sinusbot.com resolved to 104.21.13.58]
 - Time (local): 25.12.2023 09:03:06 CET +01:00:00
 - TeamSpeak3 Version: unknown
 - youtube-dl Version: 2023.11.16
newiron8
Youtube is doing changes to the API, which broke the youtube extractors used by discord-player. Maybe by changing the yt extractor it might work, but i doubt it. You should go in the discord server for discord-player if you want to know when they fix it.
