Solved Discord !yt commandes
tutur1004
Operating System: Debian (linux)
TS3 Version
: Discord :)
Impossible to do !yt or !yqt, i have yt-dl intall but the console say me :
2017-01-19T22:56:25+01:00 sending private messages is not supported for Discord
2017-01-19T22:56:24+01:00 CHAT 2 [tutur1004 @ tutur1004] < !yt https://www.youtube.com/watch?v=EyGDFhR7ztU > / OK
If you have a working youtube-dl installation which the path is set in the config, !yt works with discord. The warning only means that the sinusbot won't send messages back. This is not implemented yet. So check out if your youtube-dl installation works by adding a job for test purposes in the webinterface => music => jobs and test if the job succeededs.
blacklagoon
Heey guys Problem is solved Update to the latest Youtube.dll.exe for windows and it will be solved dont forget to !register !password and then assign permision to your account. then its solved global chat and private chat works
