Error a manual update is required
barlap
I found my sinusbots offline, and when i try to start them it says
Version: 1.0.0-beta.1-06a54d7
what should i do?
Use NTP please, otherwise it's not precise enough.
Flosing
Tier I
Patron
what should i do?
Which operating system is running on your server? Is it a Virtual Server or a Dedicated Root?
If it is Linux, try this command and post here the issue
timedatectl
barlap
It's a vps
[[email protected] ~]# timedatectl
      Local time: Sat 2019-05-25 13:30:26 EDT
  Universal time: Sat 2019-05-25 17:30:26 UTC
        RTC time: n/a
       Time zone: n/a (EDT, -0400)
     NTP enabled: yes
NTP synchronized: no
 RTC in local TZ: no
      DST active: yes
 Last DST change: DST began at
                  Sun 2019-03-10 01:59:59 EST
                  Sun 2019-03-10 03:00:00 EDT
 Next DST change: DST ends (the clock jumps one hour backwards) at
                  Sun 2019-11-03 01:59:59 EDT
                  Sun 2019-11-03 01:00:00 EST
Flosing
Tier I
Patron
It's a vps
        RTC time: n/a
     NTP enabled: yes
RTC in local TZ: no
      DST active: yes
Your time is not sync. Activate NTP
Flosing
Tier I
Patron
You can translate that. Or use google for searching for how to enable ntp on centos.
You can also do a clean reinstall of sinusbot
barlap
i already tryed to translate and done what it says, i didn't found anything about choosing server or sync the ntp, could your write exactly commands?
I also try to reinstall vps and clear sinusbot install, i install via this script https://sinusbot-installer.de/
Himsel
did you read my post?
Where's your server located at ?
Try to sync the time with the closest one
listed here https://www.pool.ntp.org/en/
just open this file /etc/ntp.conf and paste your pool zone there
after them restart
systemctl restart ntpd
