Error "Stale Decoder detected, terminating it"
Lumpek
I'm trying to get sinusbot to work on ArchLinux. I created PKGBUILD (Pacman package creation script, included all needed files as attachement), bot itself starts, but when I connect to any server I can't play anything and after while teamspeak client starts spamming error Stale Decoder detected, terminating it. Was ever active = 0 and stops responding. I can confirm that usual TS3 (without sinusbot) works flawlessly. I tried SinusBot version 1.0.0-beta.5-b262b6a and TeamSpeak3 version 3.3.0 and 3.3.2 with no difference.
SinusBot version: 1.0.0-beta.10-202ee4d
TS Client version: 3.5.2
TS Server version: 3.11.0
OS: Arch Linux
Hardware: Don't think that really matters, it's exactly the same on both, my pc and LXC VPS
-- Logs begin at Sat 2019-04-13 21:32:00 CEST, end at Wed 2020-04-15 17:21:13 CEST. --
kwi 15 17:18:33 hostname systemd[1]: Starting Sinusbot, the Teamspeak 3 and Discord music bot...
kwi 15 17:18:33 hostname systemd[1]: Started Sinusbot, the Teamspeak 3 and Discord music bot...
kwi 15 17:18:33 hostname sinusbot[222411]:  ___ ___ _  _ _   _ ___ ___  ___ _____
kwi 15 17:18:33 hostname sinusbot[222411]: / __|_ _| \| | | | / __| _ )/ _ \_   _|
kwi 15 17:18:33 hostname sinusbot[222411]: \__ \| || .` | |_| \__ \ _ \ (_) || |
kwi 15 17:18:33 hostname sinusbot[222411]: |___/___|_|\_|\___/|___/___/\___/ |_|
kwi 15 17:18:33 hostname sinusbot[222411]: Version: 1.0.0-beta.10-202ee4d
kwi 15 17:18:33 hostname sinusbot[222411]: (C) 2013-2019 Michael Friese. All rights reserved.
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 0b6075b5          INFO   Loading instances
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 0b6075b5          INFO   Loading instance://5f3f49c5-fcca-4dc4-81bf-7cb119f7636f
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 0b6075b5 5f3f49c5 INFO   Initialization complete
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
kwi 15 17:18:33 hostname sinusbot[222411]: 2020/04/15 17:18:33 [GENERAL/YTDL   ] INFO   youtube-dl checking...
kwi 15 17:18:34 hostname sinusbot[222411]: 2020/04/15 17:18:34 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
kwi 15 17:18:34 hostname sinusbot[222411]: 2020/04/15 17:18:34 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
kwi 15 17:18:34 hostname sinusbot[222411]: 2020/04/15 17:18:34 [GENERAL/RADIO  ] INFO   RadioStation data loaded
kwi 15 17:18:34 hostname sinusbot[222411]: 2020/04/15 17:18:34 [GENERAL/RADIO  ] INFO   Imported radio stations
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  Prespawn.
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  About to run.
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 WARN   Could not create Chat-Tabletable Chat already exists
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 WARN   Could not create Notifications-Tabletable Notifications already exists
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  Could not delete from FileTransferno such table: FileTransfer
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 INFO   Starting instance ts3server://myserver.tk?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 X [MAIN] New connection
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  TS>Crashdump ENABLED,  directory is: /var/opt/sinusbot/data/ts3/0b6075b5-273a-4b11-9976-7ead121e4242/5f3f49c5-fcca-4dc4-81bf-7cb119f7636f/crashdumps
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 DEBUG  TS>DUMP defined! Dumpdir is: /var/opt/sinusbot/data/ts3/0b6075b5-273a-4b11-9976-7ead121e4242/5f3f49c5-fcca-4dc4-81bf-7cb119f7636f/crashdumps
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |TeamSpeak Client 3.5.2 (2020-04-02 07:35:52)
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |SystemInformation: Linux 5.6.3-arch1-1 #1 SMP PREEMPT Wed, 08 Apr 2020 07:47:16 +0000 x86_64 Binary: 64bit
kwi 15 17:18:44 hostname sinusbot[222411]: 2020/04/15 17:18:44 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |Using hardware aes
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |ERROR   |SoundBckndIntf|   |/opt/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: NOT_CONNECTED
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |Plugins       |   |Loading plugin: libclientquery_plugin_linux_amd64.so
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |ERROR   |Query         |   |bind failed on 127.0.0.1:25639
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 210
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |*** Time [INIT]: 210
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.12.1
kwi 15 17:18:45 hostname sinusbot[222411]: 2020/04/15 17:18:45 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /var/opt/sinusbot/data/ts3/0b6075b5-273a-4b11-9976-7ead121e4242/5f3f49c5-fcca-4dc4-81bf-7cb119f7636f/settings.db
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |ts3server: myserver.tk?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Connect to server: myserver.tk
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Trying to resolve myserver.tk
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "myserver.tk" =(h: 0.0.0.0 p:0)
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "myserver.tk" =(h: 0.0.0.0 p:0)
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 0.0.0.0:41144
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |No TSDNS found
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve unsuccessful, "_tsdns._tcp.myserver.tk" Domain name not found
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve successful, "_ts3._udp.myserver.tk" =(h: myserver.tk p:9987)
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Lookup finished: ip=0.0.0.0 port=9987 query=myserver.tk error=0
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Resolve successful: 0.0.0.0:9987
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 0.0.0.0:9987
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   New connection status 1; Error 0
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |   |Last update check was: sob. sty 1 00:00:01 2022
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |              |   |Statistics report: Not yet, next report on pt. kwi 24 21:35:14 2020
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |DEVELOP |PktHandler    |1  |Puzzle solve time: 6
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   New connection status 2; Error 0
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   New connection status 3; Error 0
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 DEBUG  Witamy joined the channel
kwi 15 17:18:46 hostname sinusbot[222411]: 2020/04/15 17:18:46 0b6075b5 5f3f49c5 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
kwi 15 17:20:12 hostname sinusbot[222411]: 2020/04/15 17:20:12 0b6075b5 5f3f49c5 INFO   TS |ERROR   |Decode        |   |Stale Decoder detected, terminating it. Was ever active = 0
< LONG SPAM HERE >
kwi 15 17:20:33 hostname sinusbot[222411]: 2020/04/15 17:20:33 0b6075b5 5f3f49c5 INFO   TS |ERROR   |Decode        |   |Stale Decoder detected, terminating it. Was ever active = 0
kwi 15 17:20:44 hostname sinusbot[222411]: 2020/04/15 17:20:44 0b6075b5 5f3f49c5 WARN   Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Timeout; Code: 500; Message: Timeout
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 INFO   KILL [admin] OK
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 DEBUG  Closed.
kwi 15 17:20:45 hostname sinusbot[222411]: 2020/04/15 17:20:45 0b6075b5 5f3f49c5 INFO   TSClient quit.
kwi 15 17:20:46 hostname sinusbot[222411]: 2020/04/15 17:20:46 0b6075b5 5f3f49c5 DEBUG  closing channels
kwi 15 17:20:46 hostname sinusbot[222411]: 2020/04/15 17:20:46 0b6075b5 5f3f49c5 DEBUG  eof from voice
DataDir = "/var/opt/sinusbot/data/"
YoutubeDLPath = "/usr/bin/youtube-dl"
ExternalFileBase = ""
LicenseKey = "nope"
DevMode = false
UserAgent = "SinusBot (1.0.0-beta.5-b262b6a)"
[TTS]
Enabled = false
Edit 24.04.2020: Still not solved
  • sinusbot.zip
