Solved Failed to init text to speech engine
holybit
Operating System: Linux Debian 8.7 (64bit)
TS3 Version: 3.0.19.4
Hardware: Intel Core i7-3770, 32GB RAM
Browser: Google Chrome 56.0
DataDir = "/home/sinusbot/data/"
ListenPort = 1337
LicenseKey = "TCuMDc/6F3UsTSXVhYAVAyiV3qBjzJX+33jICpDfzU4="
  UserAgent = "SinusBot (0.9.16-10f0fad)"
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin Digital Clock.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin sound.js
2017/02/26 14:36:08 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2017/02/26 14:36:08 X [MAIN] Starting up fake x-server...
2017/02/26 14:36:09 e24358ce          INFO   Loading instances
2017/02/26 14:36:09 e24358ce          INFO   Loading instance://53dd5221-ace2-4625-a744-8af9c77a334f
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Loading script Digital Clock
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Initialization complete
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Auto-Starting e24358ce-744f-4e40-8aa5-d9d909515cb3/53dd5221-ace2-4625-a744-8af9c77a334f in 500 ms...
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Last track was 8b0dd263-ba52-47a4-9470-043256e20be4, will auto-play soon
2017/02/26 14:36:09 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2017/02/26 14:36:09 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2017/02/26 14:36:09 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Auto-Playing last track
2017/02/26 14:36:09 e24358ce 53dd5221 DEBUG  Could not delete from Notificationsno such table: Notifications
2017/02/26 14:36:09 e24358ce 53dd5221 DEBUG  Could not insert into Notifications-Tableno such table: Notifications
2017/02/26 14:36:09 e24358ce 53dd5221 DEBUG  New channel
2017/02/26 14:36:09 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2017/02/26 14:36:09 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:1337
2017/02/26 14:36:09 e24358ce 53dd5221 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=Miese%20Musikmade&password=&cid=9&channelpassword=
2017/02/26 14:36:09 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2017/02/26 14:36:09 X [MAIN] New connection
2017/02/26 14:36:10 [GENERAL/RADIO  ] INFO   Imported radio stations
2017/02/26 14:36:10 e24358ce 53dd5221 DEBUG  TS>Crashdump ENABLED,  directory is: /home/sinusbot/data//ts3/e24358ce-744f-4e40-8aa5-d9d909515cb3/53dd5221-ace2-4625-a744-8af9c77a334f/crashdumps
2017/02/26 14:36:10 e24358ce 53dd5221 DEBUG  TS>DUMP defined! Dumpdir is: /home/sinusbot/data//ts3/e24358ce-744f-4e40-8aa5-d9d909515cb3/53dd5221-ace2-4625-a744-8af9c77a334f/crashdumps
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.19.4 (2016-07-14 10:16:58)
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.39-1+deb8u1 (2017-02-22) x86_64 Binary: 64bit
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |Using hardware aes
2017/02/26 14:36:10 X [MAIN] New connection
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |ERROR   |PulseAudio    |   |failed to connect to pulse audio server
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |ERROR   |PulseAudio    |   |pa_context_connect failed
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |ERROR   |SoundBckndIntf|   |/home/sinusbot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2017/02/26 14:36:10 e24358ce 53dd5221 DEBUG  Error on call #5
2017/02/26 14:36:10 e24358ce 53dd5221 WARN   Could not send description command: HTTP returned an error: Error; Code: 500; Message: Error
2017/02/26 14:36:10 e24358ce 53dd5221 WARN   Could not request updateChannel: HTTP returned an error: Error; Code: 500; Message: Error
2017/02/26 14:36:10 e24358ce 53dd5221 WARN   Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2017/02/26 14:36:10 e24358ce 53dd5221 DEBUG  TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 103
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |              |   |*** Time [INIT]: 103
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.1
2017/02/26 14:36:10 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /home/sinusbot/data//ts3/e24358ce-744f-4e40-8aa5-d9d909515cb3/53dd5221-ace2-4625-a744-8af9c77a334f/settings.db
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=Miese%20Musikmade&password=&cid=9&channelpassword=
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987 127.0.0.1
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   New connection status 1; Error 0
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |Last update check was: Sun Jan 1 00:00:01 2017
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |   |Checking for update
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 4
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |Update        |   |Checking for updates...
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   New connection status 2; Error 0
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   New connection status 3; Error 0
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   1 Fiqqhure joined the channel
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   TS |INFO    |PermManager   |   |Loading permissions from cache
2017/02/26 14:36:11 e24358ce 53dd5221 INFO   New connection status 4; Error 0
2017/02/26 14:36:12 e24358ce 53dd5221 INFO   TS |INFO    |Update        |   |Check license version: 1
2017/02/26 14:36:12 e24358ce 53dd5221 INFO   TS |INFO    |LicenseViewer |   |License language: en
2017/02/26 14:36:12 e24358ce 53dd5221 INFO   TS |INFO    |LicenseViewer |   |Found cached license for version 1 and language en
2017/02/26 14:36:12 e24358ce 53dd5221 DEBUG  TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{dfcf1375-5cba-463b-9468-2c9537174cb8}:17/GCLL'
2017/02/26 14:36:37 e24358ce 53dd5221 DEBUG  Storing configuration.
2017/02/26 14:38:38 e24358ce 53dd5221 INFO   SAMPLEX 960 60
2017/02/26 14:38:38 e24358ce 53dd5221 DEBUG  Deleting channel
2017/02/26 14:38:38 e24358ce 53dd5221 DEBUG  Channels now zero
2017/02/26 14:38:38 e24358ce 53dd5221 DEBUG  Done playing
- Operating System: Debian GNU/Linux 8.7 (jessie)
- Load Average: 0.08 0.09 0.06
- Uptime: 0 days, 0 hours, 59 minutes, 6 seconds
- OS APT Last Update: 26.02.2017 14:05:50 CET +01:00:00
    CPU(s):                8
    Thread(s) per core:    2
    Core(s) per socket:    4
    Socket(s):             1
    Model name:            Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
    CPU MHz:               1799.609
    Virtualization:        VT-x
- RAM: 346.66 MB/31.18 GB in use (1%)
- SWAP: 0 B/15.99 GB in use (0%)
- DISK: 1.20 GB/636.42 GB in use (0%)
   > libglib: 2.42.1-1+b1
- Status: running (PIDs: 1666 1665, User: sinusbot)
- Webinterface: port locally not reachable (Port: 1337)
- Binary: /home/sinusbot/sinusbot (MD5 Hash: 0005c8c289b99913844c9f761dbb50e9)
- Version: 0.9.16-10f0fad
   - Bot Plugin: 28b54596e19937601df973b709aa0667
   - TS3 Client: 28b54596e19937601df973b709aa0667
   - TS3Path = /home/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd6        4 (Version 3.0.19.4)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.02.24)
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; cov        atar.js; dev.js; Digital Clock.js; Digital Clock.js.store; followme.js; idle.js;        metadata.js; norecording.js; rememberChannel.js; showcase.js; sound.js; welcome        text.js
- Report date: 26.02.2017 15:10:10 CET +01:00:00 (timezone: Europe/Berlin)
- youtube-dl Version: 2017.02.24
- DiagScript version: 0.4.6
I installed the bot how the Installation Tutorial said, but when I press ALT + s and enter a text, nothing happens. Here is the TTS-Configuration I'm using:
TTS-Url: http://www.voicerss.org/controls/speech.ashx?hl=__LOCALE&src=__TEXT&c=mp3
Locale: de-de
Volume: 100
Hope someone sees what's wrong. Thank you. :)
If you are a donator, the function is disable, it will fix later ..
No. This is about TTS, not speech recognition :) About the problem itself: no clue why it's not working, but I don't know that TTS service.
Pressing ALT+S and entering a text also doesn't result in an output for me while !say <text> does.
I took a look at the request this was resulting in and noticed that the locale sent w/ the request was set to "auto" instead of the one set in the config.
Sending the exact same request w/ the correct locale worked.
Anyway, try using the !say command and if that doesn't work maybe you configured something wrong.
