First installation of Sinusbot
It's already a step by step guide - open up a terminal on your server (e.g. PuTTY from Windows, ssh from unix-like systems) and go ahead. Just follow it (if you've installed the bot using the official documentation this should be fine) and if something fails / you've got problems with one of the steps, post that step including the output you got here and we might be able to help you. You can also join the Discord server (link above) to get help faster.
David1981
Good Day, I'm very sorry for writing so late. But I had a working holiday.I just wanted to point out that I don't know how to start installing, I would probably need a step by step guide on how to do it because I'm a complete amateur. Thought how the go one after the other.I'm self-taught and I didn't really understand how linux and everything around it works.So I'm sorry to trouble you and thank you for your time . Nice day
Ericstreameru
or just use amp control panel and install sinus using that, makes server managing so much easier :)
attax420
Follow the guide I posted here:
https://forum.sinusbot.com/threads/...nged-discord-voice-api.8748/page-2#post-51789
but you need to install docker first:
https://docs.docker.com/engine/install/
I have setted up the docker container so that you just need to adjust the commands posted (add your domain or ddns) and copy+paste them into the terminal one by one.
Kind regards
aTTaX420
