iOshawott
Hi! My second instance works perfectly, first one is configured as a second but isn't working.
My first instance changes music
<16:02:21> "iMusic": A teraz gramy RMF MAXXX <- It's radio station, I check as "play when idle"
<16:02:28> "iMusic": A teraz gramy Train - Drive By <- Was still idle but changed it without my knowledge :ddd
<16:04:36> "iMusic": A teraz gramy Cleo - Lowcy gwiazd
<16:04:40> "iMusic": A teraz gramy RMF MAXXX <- changed to idle : d lol
But! There's no sound anyway. I can't delete instance because it's first and unremoveable instance so my second slot is unusable...
The problem isn't from begging, in first few days all two bots running perfectly.
What to do?
What to do?
2018-05-12T16:09:43+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-05-12T16:09:43+02:00 New connection status 4; Error 0
2018-05-12T16:09:43+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-05-12T16:09:43+02:00 New connection status 3; Error 0
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-05-12T16:09:43+02:00 New connection status 2; Error 0
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-05-12T16:09:43+02:00 New connection status 1; Error 0
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-05-12T16:09:43+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2018-05-12T16:09:43+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987 localhost
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Resolve successful: 127.0.0.1:9987
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Lookup finished: 127.0.0.1 9987 localhost 0 0
2018-05-12T16:09:43+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.localhost"
2018-05-12T16:09:43+02:00 TS |INFO |TSDNS | |DNS resolve successful, "localhost"=127.0.0.1
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Trying to resolve localhost
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI |1 |Connect to server: localhost
2018-05-12T16:09:43+02:00 TS |INFO |ClientUI | |ts3server: localhost?port=9987&nickname=iMusic&password=&cid=14&channelpassword=
2018-05-12T16:09:42+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/8a782d51-cf8f-4ecf-ae70-a23ea2e6b79a/2c7f8d97-cc1d-412c-9d02-819b2f6b3d03/settings.db
2018-05-12T16:09:42+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2018-05-12T16:09:42+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-05-12T16:09:42+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2018-05-12T16:09:42+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2018-05-12T16:09:42+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2018-05-12T16:09:42+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2018-05-12T16:09:42+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2018-05-12T16:09:42+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2018-05-12T16:09:42+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-05-12T16:09:42+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2018-05-12T16:09:42+02:00 TS |INFO | | |Using hardware aes
2018-05-12T16:09:42+02:00 TS |INFO | | |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2+deb8u5 (2017-09-19) x86_64 Binary: 64bit
2018-05-12T16:09:42+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018-05-12T16:09:42+02:00 Starting instance ts3server://localhost?port=9987&nickname=iMusic&password=&cid=14&channelpassword=
