EN [FIXED] setTimeout()
Brok3nmind
My Problem was i did'nt know how to set timeouts.
I fixed it myself and I hope you can do something with it.
JavaScript:
function (sinusbot, config) {
    var event = require('event');
    event.on('clientMove', function (ev) {
        if (ev.fromChannel == undefined) {
            setTimeout(function () {
                ev.client.chat("Your Text");
            }, 1000);
Or link: https://pastebin.com/h51cxV4c
Please check the official mozilla docs on how to use setTimeout
The setTimeout method calls the function which has been given as first parameter after the set milliseconds which should be the 2nd parameter of the setTimeout function
JavaScript:
//sends "hello world" after 2 seconds
setTimeout(() => console.log("hello world"), 2000)
DrWarpMan
He didn't post you the exact code, he just told you how does it work.
Replace console.log with thing you want there.
Then please update to the insider version which you can find under resources
DrWarpMan
Paste the code here again, and please re-check your version in "Settings" - "Info" - "About".
PS: Check logs for errors..
I dont have errors but i fixed the problem myself
Wouldn't be too bad, if you post the solution, so if someone else has such a problem in the future, can just look it up here.
EDIT: Nevermind, you even purged your initial post. Well played! 🙈
You guys didn't helped me lol
Dude, are you serious? These guys DID help you - maybe it wasn't the solution for you, but they invested time in your issue and you should be more thankful for that...
Simply deleting stuff is not how a forum works: it's supposed to help others who might run into the same problem.
