MrFreak
Moin,
sobald ich mein Sinusbot auf meinen Teamspeak verbinden lasse, hat er die Lautsprecher deaktiviert.
Ich verwende die neuste Version von Sinusbot & die Teamspeakversion 3.0.17.
Ich hab schon andere Teamspeakversionen versucht, jedoch ohne Erfolg.
- virtueller Server
- Linux Debian 9
- 8GB RAM
- 4 Kerne
Ich hoffe mir kann man helfen
MfG.
Freak
- virtueller Server
- Linux Debian 9
- 8GB RAM
- 4 Kerne
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin alonemode.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2018/03/06 16:08:32 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcome.js
2018/03/06 16:08:32 463c2899 INFO Loading instances
2018/03/06 16:08:32 463c2899 INFO Loading instance://f74dc742-dc1b-461e-ab5a-d1b4a2c4bd09
2018/03/06 16:08:32 463c2899 f74dc742 INFO Initialization complete
2018/03/06 16:08:32 463c2899 f74dc742 INFO Auto-Starting 463c2899-adaa-4877-8bb5-872cba8ff078/f74dc742-dc1b-461e-ab5a-d1b4a2c4bd09 in 500 ms...
2018/03/06 16:08:32 463c2899 INFO Loading instance://992a06fc-94ad-4c19-97f4-6f9fe27b058e
2018/03/06 16:08:32 463c2899 992a06fc INFO Initialization complete
2018/03/06 16:08:32 463c2899 992a06fc INFO Auto-Starting 463c2899-adaa-4877-8bb5-872cba8ff078/992a06fc-94ad-4c19-97f4-6f9fe27b058e in 1000 ms...
2018/03/06 16:08:32 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2018/03/06 16:08:32 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2018/03/06 16:08:32 [GENERAL/YTDL ] INFO youtube-dl checking...
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG Prespawn.
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG About to run.
2018/03/06 16:08:33 463c2899 f74dc742 WARN Could not create Chat-Tabletable Chat already exists
2018/03/06 16:08:33 463c2899 f74dc742 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/03/06 16:08:33 463c2899 f74dc742 WARN Could not create Notifications-Tabletable Notifications already exists
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/03/06 16:08:33 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2018/03/06 16:08:33 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2018/03/06 16:08:33 [GENERAL/RADIO ] INFO RadioStation data loaded
2018/03/06 16:08:33 463c2899 f74dc742 INFO Starting instance ts3server://ZENSIERT?port=9987&nickname=Sinusbot2&password=&channel=&channelpassword=
2018/03/06 16:08:33 X [MAIN] New connection
2018/03/06 16:08:33 [GENERAL/RADIO ] INFO Imported radio stations
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG TS>Crashdump ENABLED, directory is: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/f74dc742-dc1b-461e-ab5a-d1b4a2c4bd09/crashdumps
2018/03/06 16:08:33 463c2899 f74dc742 DEBUG TS>DUMP defined! Dumpdir is: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/f74dc742-dc1b-461e-ab5a-d1b4a2c4bd09/crashdumps
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |TeamSpeak 3 Client 3.0.17 (2015-08-04 07:38:33)
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |SystemInformation: Linux 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64 Binary: 64bit
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |ERROR |PulseAudio | |pa_context_connect failed
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/03/06 16:08:33 463c2899 992a06fc DEBUG Prespawn.
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO |Query | |listening on 127.0.0.1:25639
2018/03/06 16:08:33 463c2899 f74dc742 INFO TS |INFO | | |Api version is not compatible for plugin: /opt/bot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2018/03/06 16:08:33 463c2899 992a06fc DEBUG About to run.
2018/03/06 16:08:33 463c2899 992a06fc WARN Could not create Chat-Tabletable Chat already exists
2018/03/06 16:08:33 463c2899 992a06fc WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/03/06 16:08:33 463c2899 992a06fc WARN Could not create Notifications-Tabletable Notifications already exists
2018/03/06 16:08:33 463c2899 992a06fc DEBUG Could not delete from FileTransferno such table: FileTransfer
2018/03/06 16:08:33 463c2899 992a06fc DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/03/06 16:08:33 463c2899 992a06fc INFO Starting instance ts3server://ZENSIERT?port=9987&nickname=Sinusbot&password=&channel=&channelpassword=
2018/03/06 16:08:34 X [MAIN] New connection
2018/03/06 16:08:34 463c2899 f74dc742 DEBUG TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI | |Qt version: 5.4.1
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI | |Using configuration location: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/f74dc742-dc1b-461e-ab5a-d1b4a2c4bd09/settings.db
2018/03/06 16:08:34 463c2899 992a06fc DEBUG TS>Crashdump ENABLED, directory is: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/992a06fc-94ad-4c19-97f4-6f9fe27b058e/crashdumps
2018/03/06 16:08:34 463c2899 992a06fc DEBUG TS>DUMP defined! Dumpdir is: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/992a06fc-94ad-4c19-97f4-6f9fe27b058e/crashdumps
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |TeamSpeak 3 Client 3.0.17 (2015-08-04 07:38:33)
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |SystemInformation: Linux 4.9.0-6-amd64 #1 SMP Debian 4.9.82-1+deb9u3 (2018-03-02) x86_64 Binary: 64bit
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |ERROR |PulseAudio | |failed to connect to pulse audio server
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |ERROR |PulseAudio | |pa_context_connect failed
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |Loading plugin: libclientquery_plugin
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |Loading plugin: liblua_plugin
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |Loading plugin: libsoundbot_plugin
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |Loading plugin: libtest_plugin
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO | | |Api version is not compatible for plugin: /opt/bot/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI | |ts3server: ZENSIERT?port=9987&nickname=Sinusbot2&password=&channel=&channelpassword=
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Connect to server: ZENSIERT
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Trying to resolve ZENSIERT
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |TSDNS | |DNS resolve successful, "ZENSIERT"=ZENSIERT
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.ZENSIERT"
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2018/03/06 16:08:34 463c2899 f74dc742 INFO TS |INFO | | |Statistics report: Not yet, next report on Mo. März 19 15:53:08 2018
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO |ClientUI | |Qt version: 5.4.1
2018/03/06 16:08:34 463c2899 992a06fc INFO TS |INFO |ClientUI | |Using configuration location: /opt/bot/data/ts3/463c2899-adaa-4877-8bb5-872cba8ff078/992a06fc-94ad-4c19-97f4-6f9fe27b058e/settings.db
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |ClientUI | |ts3server: ZENSIERT?port=9987&nickname=Sinusbot&password=&channel=&channelpassword=
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Connect to server: ZENSIERT
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Trying to resolve ZENSIERT
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |TSDNS | |No SRV TSDNS found at "_tsdns._tcp.ZENSIERT"
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |TSDNS | |DNS resolve successful, "ZENSIERT"=ZENSIERT
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |TSDNS | |SRV DNS resolve unsuccessful for "_ts3._udp.ZENSIERT"
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO |ClientUI | |Last update check was: Di. Jan. 1 00:00:01 2019
2018/03/06 16:08:35 463c2899 992a06fc INFO TS |INFO | | |Statistics report: Not yet, next report on Mi. März 7 15:54:38 2018
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Lookup finished: ZENSIERT 9987 ZENSIERT 0 0
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Resolve successful: ZENSIERT:9987
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Initiating connection: ZENSIERT:9987 ZENSIERT
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2018/03/06 16:08:38 463c2899 f74dc742 DEBUG TS>AA ts3.alsa.dummy.playbackdefault 5
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |ERROR |ALSA | |snd_pcm_open: Datei oder Verzeichnis nicht gefunden
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2018/03/06 16:08:38 463c2899 f74dc742 INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2018/03/06 16:08:39 463c2899 f74dc742 DEBUG TS>AA ts3.alsa.dummy.capturedefault 5
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |ERROR |ALSA | |snd_pcm_open: Datei oder Verzeichnis nicht gefunden
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Lookup finished: ZENSIERT 9987 ZENSIERT 0 0
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Resolve successful: ZENSIERT:9987
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Blacklist check ok
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Initiating connection: ZENSIERT:9987 ZENSIERT
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 2
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2018/03/06 16:08:39 463c2899 f74dc742 INFO TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2018/03/06 16:08:39 463c2899 992a06fc DEBUG TS>AA ts3.alsa.dummy.playbackdefault 5
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |ERROR |ALSA | |snd_pcm_open: Datei oder Verzeichnis nicht gefunden
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |ERROR |SoundBckndIntf| |/opt/bot/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2018/03/06 16:08:39 463c2899 992a06fc DEBUG TS>AA ts3.alsa.dummy.capturedefault 5
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 1
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Connect status: Disconnected
2018/03/06 16:08:39 463c2899 992a06fc INFO TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
TS3Path = "/opt/bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
DataDir = "/opt/bot/data/"
YoutubeDLPath = "/opt/youtube-dl"
LicenseKey = "HUBtWjJ5scq2S9ZHaXsLXmm+9spg73a+dSXO6SBHNXo="
ChunkSize = 5242880
MfG.
Freak
