Feature get Instance Settings
Dampfklon
I would like to see the Instance Settings exposed to the scripting api.
eg. Default Channel, Nickname
kanalumaddela
This is already possible? The script "Remember Last Channel" which is included with the bot does what it says and changes the default channel when it is moved to another channel. The script !rename changes the bot nickname, so I don't see what you mean by having the instance settings "exposed".
Dampfklon
The script "Remember Last Channel" uses sinusbot.setDefaultChannel(channel) the function I Request is sinusbot.getDefaultChannel() as well as sinusbot.getDefaultUsername() and the other settings which you configure on the instance settings page http://example.cpm//settings/general
There are Scipts like BackToDefault which moves the bot to a default channel but you must configure this channel in the scripts settings bc. you cant get the settings from the bot.
kanalumaddela
No why wasn't this your first post? Mhhmmm idk? It would've made more sense if you started with that instead, but now I can understand what you're saying.
