EN [Help] can't use http
K4M1ss
#stayinghome
Hi. My problem is that i can't import http library to my script...
Error: require() could not resolve import: http
Any ideas?
no longer active
requires sinusbot v0.14 or later, you're probably using the windows version that's still on v0.13
K4M1ss
#stayinghome
I'm using Sinusbot 0.13.37 on linux. Do I have to update it to beta version or something?
Edit: Ok nevermind. I found correct version. Thanks for help :)
