Solved Help me with start sinusbot, it does not connect to server
Hi, im trying to install it on Centos 7. And no result. Sinusbot version is 1.0.0-beta.1-06a54d7. TS client (on linux is 3.2.5, sever is the same machine 3.5.0).
Where i can find bot and ts3 logs?
Log from instance:
2019-06-12T21:37:05+02:00 TSClient quit.
2019-06-12T21:37:05+02:00 Closed.
2019-06-12T21:37:05+02:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2019-06-12T21:37:05+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-06-12T21:37:05+02:00 TS>Qt: Could not determine keyboard configuration data from X server, will use hard-coded keymap configuration.
2019-06-12T21:37:05+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-06-12T21:37:04+02:00 New connection status 0; Error 0
2019-06-12T21:37:04+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019-06-12T21:37:04+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2019-06-12T21:37:04+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2019-06-12T21:37:04+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 3
2019-06-12T21:37:04+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-06-12T21:37:04+02:00 New connection status 1; Error 0
2019-06-12T21:37:04+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI |1 |Initiating connection: IPADDR:9987
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI |1 |Resolve successful: IPADDR:9987
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI |1 |Lookup finished: ip=IPADDR port=9987 query=myhostname error=0
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.mydomain" Domain name not found
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.myhostname" Domain name not found
2019-06-12T21:37:03+02:00 TS |INFO | | |Statistics report: Not yet, next report on Mon Jul 8 18:16:46 2019
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-06-12T21:37:03+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |No TSDNS found
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully IPADDR:41144
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "mydomain" =(h: IPADDR p:0)
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "myhostname" =(h: IPADDR p:0)
2019-06-12T21:37:03+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "myhostname" =(h: IPADDR p:0)
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI |1 |Trying to resolve myhostname
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI |1 |Connect to server: myhostname
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI | |ts3server: myhostname?port=9987&nickname=mbot&password=&channel=DOTA&channelpassword=
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/4c68086b-2eaa-436b-b446-4ca775370366/295099d4-4fd5-4eff-9fa8-faf76b760a37/settings.db
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-06-12T21:37:03+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-06-12T21:37:03+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019-06-12T21:37:03+02:00 TS |INFO | | |*** Time [INIT]: 220
2019-06-12T21:37:03+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 220
2019-06-12T21:37:03+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-06-12T21:37:02+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-06-12T21:37:02+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-06-12T21:37:02+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-06-12T21:37:02+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-06-12T21:37:02+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-06-12T21:37:02+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-06-12T21:37:02+02:00 TS |INFO | | |Using hardware aes
2019-06-12T21:37:02+02:00 TS |INFO | | |SystemInformation: Linux 3.10.0-957.10.1.el7.x86_64 #1 SMP Mon Mar 18 15:06:45 UTC 2019 x86_64 Binary: 64bit
2019-06-12T21:37:02+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-06-12T21:37:02+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/4c68086b-2eaa-436b-b446-4ca775370366/295099d4-4fd5-4eff-9fa8-faf76b760a37/crashdumps
2019-06-12T21:37:02+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/4c68086b-2eaa-436b-b446-4ca775370366/295099d4-4fd5-4eff-9fa8-faf76b760a37/crashdumps
2019-06-12T21:37:01+02:00 Starting instance ts3server://myhostname?port=9987&nickname=mbot&password=&channel=DOTA&channelpassword=
2019-06-12T21:37:01+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-06-12T21:37:01+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-06-12T21:37:01+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-06-12T21:37:01+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-06-12T21:37:01+02:00 Could not create Chat-Tabletable Chat already exists
2019-06-12T21:37:01+02:00 About to run.
2019-06-12T21:37:01+02:00 Prespawn.
2019-06-12T21:36:48+02:00 script command loaded
2019-06-12T21:36:48+02:00 module registered as command
2019-06-12T21:36:48+02:00 registered callback for event chat
2019-06-12T21:36:48+02:00 Initialization complete
2019-06-12T21:36:47+02:00 executing script command
What can i check and how? Identity is 8 and server minimal is 8 too.
How can i reinstall ts3 client on linux?
Maybe the problem is ido not have desktop and firefox on this system? Do i really need it to sinusbot work?
Kir-à
How did you installed Sinus ?
There definitely corrupted data.
You should delete everything and reinstall it from the installer.
Hope it help!
In 99% of cases its one of the following:
Suggesting to update to 3.8.0, your version is almost 9 months old.
Suggesting furthermore, you'd better tell your bot where to connect to. ;)
He knows where, i changed hostname to this and domain name i dns resolv, not to put it in the internet. Addresses are ok.
Server exists at this address, im using it:)
No pass on the server.
Default channel has other name, but good name in bot settings.
Illegeal - no its free up to 32 slots.
Security level is one lower or the same - does not help.
Nickname is mbot. On musisbot the same.
or the server does not allow the version of the client you are using. - how to check it?
Use a TS-client with version 3.2.5 and connect to your server ;)
ofc windows 3.2.5 works ok (normal client). Ill try to update to 3.8 my server and we will see. However in instruction there is no information how to uninstall or completely remove this instalation. May You confirm how linux client can be uninstalled? And sinusbot also?
Cause if updating server will not help ill try script.
Bad part of this is logging in sinusbot - we have no information what is wrong to repair it - its very poor.
OK. i have deleted all and used script.
Log here:
2019-06-15T14:09:17+02:00 TSClient quit.
2019-06-15T14:09:16+02:00 TS |INFO | | |Statistics report: Not yet, next report on Wed Jul 3 13:59:34 2019
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019-06-15T14:09:16+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019-06-15T14:09:16+02:00 New connection status 0; Error 0
2019-06-15T14:09:16+02:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Disconnected or forced to leave, want autoreconnect = 0
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2019-06-15T14:09:16+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 4
2019-06-15T14:09:16+02:00 New connection status 1; Error 0
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2019-06-15T14:09:16+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Initiating connection: ipaddr:9987
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Resolve successful: ipaddr:9987
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Lookup finished: ip=ipaddr port=9987 query=ts3.mydomainmydomain error=0
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |No TSDNS found
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |TSDNS queried unsuccessfully ipaddr:41144
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.ts3.mydomainmydomain" Domain name not found
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.mydomainmydomain" Domain name not found
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "mydomainmydomain" =(h: ipaddr p:0)
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "ts3.mydomainmydomain" =(h: ipaddr p:0)
2019-06-15T14:09:16+02:00 TS |INFO |TSDNS | |A/AAAA DNS resolve successful, "ts3.mydomainmydomain" =(h: ipaddr p:0)
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Trying to resolve ts3.mydomainmydomain
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI |1 |Connect to server: ts3.mydomainmydomain
2019-06-15T14:09:16+02:00 TS |INFO |ClientUI | |ts3server: ts3.mydomainmydomain?port=9987&nickname=MusicBot2&password=&channel=&channelpassword=
2019-06-15T14:09:15+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/70fd67a9-143d-4ac1-959d-4bad5e2c10d3/9bea8051-07e5-4f3e-b631-511444ca6d3d/settings.db
2019-06-15T14:09:15+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2019-06-15T14:09:15+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2019-06-15T14:09:15+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2019-06-15T14:09:15+02:00 TS |INFO | | |*** Time [INIT]: 270
2019-06-15T14:09:15+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 270
2019-06-15T14:09:15+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019-06-15T14:09:15+02:00 TS |INFO |Query | |listening on 127.0.0.1:25639
2019-06-15T14:09:15+02:00 TS |INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2019-06-15T14:09:15+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-06-15T14:09:15+02:00 TS |INFO | | |*** Time [ICONMANGER]: 110
2019-06-15T14:09:15+02:00 TS |INFO | | |successfully downloaded revocation list for accounting
2019-06-15T14:09:15+02:00 TS |INFO | | |successfully downloaded revocation list for myteamspeak id
2019-06-15T14:09:15+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-06-15T14:09:15+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-06-15T14:09:15+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019-06-15T14:09:15+02:00 TS |INFO | | |Using hardware aes
2019-06-15T14:09:15+02:00 TS |INFO | | |SystemInformation: Linux 3.10.0-957.21.2.el7.x86_64 #1 SMP Wed Jun 5 14:26:44 UTC 2019 x86_64 Binary: 64bit
2019-06-15T14:09:15+02:00 TS |INFO | | |TeamSpeak 3 Client 3.2.5 (2019-04-17 16:07:33)
2019-06-15T14:09:14+02:00 Starting instance ts3server://ts3.mydomainmydomain?port=9987&nickname=MusicBot2&password=&channel=&channelpassword=
2019-06-15T14:09:14+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-06-15T14:09:14+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-06-15T14:09:14+02:00 Could not create Chat-Tabletable Chat already exists
2019-06-15T14:07:38+02:00 script command loaded
2019-06-15T14:07:38+02:00 Initialization complete
If ts3 client is in /opt/sinusbot/teamspeak3_client i got this error:
[[email protected] teamspeak3-client]$ ./ts3client_linux_amd64
./ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
server is now 3.8
OK guys i found problem. It looks, my manual installaton was working like script one.
But Yatqa shows i got 8lvl identity, and manually checked on server and there is 14lvl. After decreasing this parameter bot is on channel.
Now ill need to upgrade bot level.
Thanx for help.
Got some other questions:
1. How can i add permission to not flood ts for musisc bot?
2. How can i run nicknames like this: https://github.com/xDefcon/sinusbot-scripts ?
3. How to change password default which i got from the installer? When i do ./sinusbot --override-password=newpassword new password is working. But then i stop bot with ctrl + Z or C and then i run it with systemctl. Old password working, not new one.
4. What is this password - user accounts - admin - edit ?
Himsel
That's a lot of questions you could easy find out by yourself.
1. Add your Bot to a server group with "ignore anti flood" permission on
2. Download the script and drop it into the scripts folder. Then restart sinusbot
3. You could try to stop sinusbot first, with service sinusbot stop
4. This is the password which you tried to change in the third question. You also can change it with the installer script btw.
5. Also there in "edit user account" you can add Servergroups and/or bind an identity
1. ok
2. not working or i do not know how to edit names to let them got animation
3. Did 4.
4. Now i know:)
5. i did.
thanks, what about 2?
Thanx for help.
For others with such kind of problem, here is OP's solution.
How to confirm as solved?
The script works, but i see on general ts3 chat all messages that nickname is changing, can i disable it?
Also, last question (do not want to open new thread for this) - do u have the same when u r alone with bot (dont know what happened when mote users are there) and u join other channel and went back to music channel it starts to play new song - is it normal?
i found its cause of NextTrack script.
