EN Help with http response
CaS5
I'm making an attempt at fixing the steam servers information script that was broken with the http update. I've already fixed the obsolete sinusbot.http code, but I'm returning an undefined response. I'm assuming it's because I'm using simpleRequest? Do I need to use simpleRequestCallback? It's returning engine.log('Response Undefined');
JavaScript:
    function update() {
        const http = require('http');
        if (backend.isConnected()){
            http.simpleRequest({
              "method": "GET",
              "url":    "https://crowbar.steamstat.us/Barney",
              "timeout": 6000,
              "headers": {"User-Agent": "curl/7.47.0"}
            }, function (error, response) {
                if (typeof response != 'undefined' && response.statusCode == 200) {
                    var serverInformation = JSON.parse(response.data);
                    if (typeof serverInformation != 'undefined') {
                        if (typeof serverInformation.error != 'undefined') {
                            engine.log("API Error: " + serverInformation.error);
                        processServers(config, serverInformation);
                    } else {
                  engine.log("ERROR: invalid response: " + response.data);
              }else{
                if (typeof response != 'undefined'){
                }else{
                    engine.log('Response ERROR: '+response.statusCode);
DrWarpMan
JavaScript:
    function update() {
              "method": "GET",
              "timeout": 6000,
                    } else {
              }else{
                }else{
I tried to fix this script 3 months ago, and I have also discussed this with Sinusbot staff and we came to an end, that the site is using cloudflare, and that is the reason why do you get undefined, because cloudflare blocks your IP address. For some reason, we can open the page normally, but not through a VPS (like mine or yours I guess).
TL;DR
"You can't do much about a cloudflare ban/block, except contacting them" - said @irgendwr 3 months ago :D
