You post "I can not login to ip, to configure the bot! I already entered the login right here in the forum and gave nothing!" then "I got it but now my problem is another, how do I put the bot in my discord?" and then " I do not want for the discord, I want for the teamspeak!" and after all "
The bot's identity on the 'Instance Settings' tab is not working. On this server I want to put the bot, I need to know the unique ID of it!"
First of all read the FAQ, check the full guide of how to install sinusbot and when you need help post with all the details and config logs so we can help you, otherwise we can think you are trolling just posting all your error steps. I understand you are Brazilian, im from mexico but i take my time to make posts and to explain sometimes what i need.
