How to fix lagg?
Draftking
Hi how can i fix the lagg in my bot? i have a internet connection of 130 mb/s so thats allright.
here is my config:
LogLevel = 3
YoutubeDLPath = "C:\\SinusBot\\youtube-dl.exe "
MTU = 1500
SampleInterval = 100
LicenseKey = "txoWgjWbv2BjJNd6ZXaSYEaclz7bhasfs44hA1s//S0="
EnableAloneMode = false
kanalumaddela
130 Mb/s doesn't matter since that's download speed, you should focus on your UPLOAD speed. Try adjusting the sample interval in intervals of 20. I found that 40 worked best for me. Adjust the value both up and down and see which values produce the least lag. If there is still lag, make sure the computer it is running on is capable of running the bot (this shouldn't be an issue)
