Solved HTTPS location, in release post, references old [linux] build
siysco
HTTPS Download Location References Old Build
The https location, published in the SinusBot Beta 0.13.37-f7e9ece release post, references sinusbot version 0.10.8-71ba94b instead of 0.13.37-f7e9ece. Therefore, the "mini guide" in the post can be confusing. The download button, in the SinusBot Beta 0.13.37-f7e9ece release post, does download the correct version; 0.13.37-f7e9ece. The files can be downloaded manually and the update applied manually. It's a lot slower, but it does work.
For anyone having issues upgrading, make sure you read the release notes posted here - they will help.
Version 0.13.37-f7e9ece md5sum
9e74167de6a4b9931e381cc86bf05b3e
Version 0.10.8-71ba94b md5sum
febce0ebdd2d2e9d7f69701bc5a7c339
Thanks for this detailed post!
I updated the instructions, should be correct now.
I'm getting a different md5 hash from the binary contained in dl/sinusbot.current.tar.bz2. This might be older version as well.
# md5sum sinusbot
f42a573b7435a8ff04da446d5ccbe754  sinusbot
I took the SOLVED tag off this post ... I'm not sure if I'm supposed to do that!
The version that get's downloaded via current is 0.13.37-9791176 which is basically the same as 0.13.37-f7e9ece so it's fine.
Small patches are not worth pushing an update for every time.
"current" should always be the latest (public) release assuming flyth didn't mix something up ^^
